Concrete Mixing - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-06-2011, 08:22 AM   #1
Concrete Mixing
Hope this the right area to post ~
For relatively small jobs I can see the premix with rented concrete mixer setup etc. But, say I wanted to pour a foundation for a 10x10 shed or the like. I figure roughly 50 80~Lb bags or concrete @ .6 cu ft / bag. The largest mixers I see online are around 6 cu ft. I would opt for renting I'm sure. Doesn't this have to be one continuous pour? Wouldn't you have to pour, rinse & clean mixer, fill & mix concrete, repeat etc. Seems like a lot of "in between" time during pours. Seems like you'd need 2 or more mixers operating simultaneously. I've only done basic patch work mixing by hand/stick in a 5 gallon bucket but would like to expand my concrete skills & abilities to do bigger more meaningful projects.
kevsprojects is offline   Reply With Quote
Old 08-06-2011, 08:48 AM   #2
biggles's Avatar
ever consider doing it in sections moving the form and or even mixing it up within the form with 2x6s instead of 2x4s.saw a house show where they have a rolling cement truck that gives out amounts asked for instead of the entire cement mixer being just for your job...
Old 08-06-2011, 09:15 AM   #3
I've heard of the pour on the fly or on the roll concept. I'll check on that. Mixing it in the forms sound like a neat idea. I'll try to find any videos on that!
Old 08-06-2011, 09:23 AM   #4
Civil Engineer
Rewards Points: 4,566
A 10 ft x 10 ft foundation 6 inches thick is about 2 yards of concrete, which gets you into the zone where buying readimix could make sense. Each yard of concrete weights about 4,000 lbs - 5,000 lbs, so if you have a heavy duty truck, you may be able to buy trailer mix concrete and transport it yourself (see http://www.rentalhq.com/article.asp?artid=69&cat=con).
That is a lot of concrete to hand mix, not saying you can't do it, but you do have issues of timing and setting of the concrete, especially if it is hot.
Old 08-06-2011, 09:41 AM   #5
joed's Avatar
Rewards Points: 11,998
Pour and mix the next batch. No washing rinsing in between. It's only concrete in the mixer from the last load.
Old 08-06-2011, 09:51 AM   #6
Now that's a neat idea! I might need a more robust truck though. Actually, I don't see how I could do it with a "simple" mixer because of the timing issue mentioned before. Seems like a one shot single pour is the only way!
Old 08-06-2011, 10:06 AM   #7
biggles's Avatar
YOU TUBE has a ton of videos...try this one out on doing the bags of cement without a delivery....
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
Concrete Footing for Charcoal Grill Post rexpfur Building & Construction 7 07-31-2011 10:00 PM
Crumbling Front Porch - Part 2 - The Repair jerseyguy1996 General DIY Discussions 9 04-11-2010 07:11 AM
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 01:03 PM
