Concrete Interwalls Old House - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-03-2010, 06:53 PM   #1
Question
concrete interwalls old house
have old home with concrete block walls. are now wallpapered some of it is coming loose would like to remove. would like to paint wall but you see each block, don't like that. is there a product that can be put on the wall without drywalling the whole thing. have done that in other rooms. help
Cthompson is offline   Reply With Quote
Old 12-06-2010, 09:13 PM   #2
Registered User
Termite's Avatar
First, welcome to the site! I moved your thread to the general discussion from the how-to guides section...It'll get more attention here.
Drywalling over block exterior walls probably isn't a great idea due to the possibility of moisture vapor penetrating the walls. Mold, etc. You could probably do some sort of stucco coat on the interior of the house if you want to hide the block look. Then paint that.
The Following User Says Thank You to Termite For This Useful Post:
Cthompson (01-03-2011)
Old 12-07-2010, 02:05 AM   #3
Rewards Points: 1,092
If the walls are clean, you could "butter them up" w/ the type of mortar they use (or used to?) to seal blocks. (No rock, of course, and a little extra lime, if I recall what my Dad did). You can get that pretty smooth, or at least an experienced person could. Just a thought. Glue on wood paneling?
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 09:37 PM
anchoring concrete stairs to the house amakarevic Building & Construction 2 06-14-2010 03:25 PM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 04:47 PM
Concrete Repair Help / Contractor Problems thp Building & Construction 12 09-24-2009 01:01 PM
Concrete settling away from house ???? ELECTRIC07 General DIY Discussions 1 03-12-2009 06:13 AM
