Concrete Form Over Uneven Surface - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-16-2011, 07:47 AM   #1
Concrete form over uneven surface
Hi,
I am remodeling a raised box fireplace with thinstone, and I have demolished the badly made raised hearth. I need to repour a new raised hearth and intend to make concrete forms. Problem is that the existing remains of the old hearth are bumpy.
I am looking for any tips on building my concrete form over this uneven surface.
Thanks,
CV
cvbrewer is offline   Reply With Quote
Old 08-16-2011, 11:35 AM   #2
Rewards Points: 6,652
Have you tried putting a level down to see how much difference there is between areas? If there is seepage after you pour, you would just grind or chisel for clean up. Otherwise you can chisel before you do the pour. Any chance of a picture of the area that you are dealing with, showing what you are talking about.
Old 08-16-2011, 01:00 PM   #3
Rewards Points: 5,336
Depends on how bumpy. Slight irregularities will not be an issue. Just keep the mix away from the soupy side. A standard consistancy will leak a bit, but not much. If it's more then 1/2", use backer rod for the gaps and hold it down with a second piece of wood on the outside.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
mustangmike3789 (08-21-2011)
Old 08-16-2011, 10:25 PM   #4
Run duct tape along the uneven concrete with the edge even with the inside of where the form board will be (shown above in black. Run a second strip of duct tape as shown in blue. Set the form and fill the space between form and tape with spray foam. After the foam sets, use a sharp knife to trim the foam even with the inside of the form. Remove the excess foam and tape from the inside of the forming.
pls8xx is offline   Reply With Quote
Old 08-16-2011, 10:47 PM   #5
Too Short? Cut it Again!
Not sure I fully understand what you are trying to accomplish. But why be mindset on concrete for the repair? Would an epoxy compound work? I use this stuff all the time for concrete repairs. It is lighter and stronger when cured. You can sculpt it as you go with some practice.
www.abatron.com
Not sure about standing up to heat in a hearth though. You would have to ask the company I guess.
Old 08-21-2011, 06:55 AM   #6
thanks everyone. I got the form made, and there only seem to be moderate gaps between the form and the existing concrete pad. I am going to try tape on the inside and spray foam or caulk on the outside.
Old 08-21-2011, 07:32 AM   #7
DIY staff
Rewards Points: 7,174
Pack the gap with plumbers putty.
replacing wall tile on uneven surface johnpaul8379 Kitchen & Bath Remodeling 2 02-22-2011 03:26 PM
What is the on the base of the footing for standard circular steel form work for concrete be 12" wall and 36' foundation undation? william lum Building & Construction 1 06-24-2010 06:45 PM
Annie5 - framing over uneven concrete floor Annie5 Carpentry 9 11-22-2009 03:26 PM
Very bumpy concrete floor that is not level cgcaudle Flooring 1 08-31-2008 04:04 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
