Concrete Drying Time? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-18-2011, 02:42 PM   #1
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Concrete CURING time? w/ new question
Yesterday I poured a landing pad for my deck stairs. 5' x 2' x 6".
I finished around 5 or 6PM.
I just realized I have Friday off work which presents a perfect opportunity to actually finish the stairs. What do you all think - is that enough time for them to dry?
I don't have to walk on the stairs while building them so the load would be minimal if it had to be.
[Thanks guys for reminding me it does not "dry" - it "cures" - I changed the title, not sure why it doesn't show up]
CoconutPete is offline   Reply With Quote
Old 04-18-2011, 02:59 PM   #2
Rewards Points: 5,336
You can build on it Wednesday.
Ron
Old 04-18-2011, 03:01 PM   #3
Rewards Points: 504
Well that's certainly good news - thanks
Old 04-18-2011, 03:18 PM   #4
Old School
Willie T's Avatar
Geez! How much do you weigh?
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
CookeCarpentry (04-21-2011)
Old 04-18-2011, 03:20 PM   #5
Rewards Points: 504
Why, does the pad seem big? Haha.
The stairs are going to be 4' wide.
Old 04-18-2011, 03:24 PM   #6
Old School
Willie T's Avatar
Well, both the depth of the pad and the long drying time for pedestrian traffic.
Willie T
Old 04-18-2011, 04:07 PM   #7
concretemasonry's Avatar
Rewards Points: 2,570
Concrete does not dry. - It cures and gets stronger. Even if it seems hard and is only a few days old, you can still scar or scrape the surface even if it is strong enough for the use.
It will continue to gain strength for a year or two if there is moisture available and a slab on grade usually has enough moisture under it to allow some more curing. The 28 days is just a time period for meeting or measuring the strength.
Dick
concretemasonry is online now   Reply With Quote
Old 04-18-2011, 04:13 PM   #8
Rewards Points: 504
Great. I will build on Friday then. I'll make sure to keep heavy items off it for as long as possible.
Old 04-21-2011, 01:05 PM   #9
Rewards Points: 504
Pulled the form yesterday. Seems nice and solid. By the time tomorrow rolls around I feel fine building the stairs on it.
Side question: Have you guys ever used a grinding wheel or anything like it on a pad? The edges are not "razor sharp" but they are certainly not rounded either - it would be nice to round them off a little bit in case someone comes running up the stairs in bare feet.
Old 04-21-2011, 02:07 PM   #10
Old School
Willie T's Avatar
It won't look as good as if you had used your edging tool, but a hunk of a broken concrete block will take off the edge. Just rub it along the edge.
Willie T
Old 04-21-2011, 03:38 PM   #11
Rewards Points: 504
Hmm.... very resourceful. I like that!
Drying Time Bob Guercio Painting 2 02-25-2011 11:02 AM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 12:12 PM
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 10:37 PM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
epoxy coat and resurfacing concrete cure time questions ?? waltereo Flooring 3 10-04-2008 12:43 PM
