Concrete Board In Shower, Need Help Please! - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-28-2008, 04:28 PM   #16
Handyman/ Snow Removal
So "It will bond much better" Is the same as what they're telling you.
McGaw is offline   Reply With Quote
Old 02-29-2008, 06:23 PM   #17
She'sapainter
I don't know if your replying to my last message, but what the red gard will do is waterproof you seems and you can put it over your cement board and create a rougher surface for the mortar.
A drop cloth isen't to catch paint, It's to protect what is under so wipe the drips as you go and don't track.
tverhoef is offline   Reply With Quote
Old 02-29-2008, 06:43 PM   #18
No, I was replying to Floxy.
Old 03-01-2008, 07:15 PM   #19
Tile Contractor
Bill_Vincent's Avatar
Although the rough side will give you more area to grab, the smooth side can also be used..... even for thinset. Don't waste your money on Redgard, if the only reason you're using it is as a bonding surface. it's completely unnecessary, unless you were planning on waterproofing the cement board anyway.
"Whether you think you can, or you think you can't, You're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline   Reply With Quote
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
Concrete Shower Pans??? seaturtle General DIY Discussions 10 01-21-2008 03:26 PM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
Concrete board installation HELP! irlizard Flooring 4 07-28-2006 09:35 PM
