Concrete Basement Floor. - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-19-2010, 07:00 PM   #1
Question
Concrete basement floor.
I'm adding a basement bathroom (close to the main drain) to a 50yr old home. I have most of the trench dug for the shower drain, but I've come to a point where the concrete floor changes from being 3 or 4 inches thick to 12" thick!! The area in question is 3' from an outside wall and 6" from the main drain which I've already exposed.
Any thoughts on why this might be? Will I be compromising structure if I bust it up?
Thanks in advance.
Lunker is offline   Reply With Quote
Old 01-20-2010, 03:31 PM   #2
Probably part of a footing. I doubt you'd want to "bust it up" without consulting an engineer first.
klein is offline   Reply With Quote
Old 01-20-2010, 05:42 PM   #3
Registered User
Termite's Avatar
Hard to say. It is not uncommon for slabs to be thickened and extra reinforcement is added as an approach to adding some bearing/structure to the slab due to various reasons. Normally there would be a wall running on a thickened portion of a slab, but not always. It is equally likely that they just had extra concrete when they poured the slab.
Only way to know for sure is to have an engineer take a look at it.
Old 01-20-2010, 05:47 PM   #4
some times an area taht does not compact well will have bad fill removed and concrete vs gravel will be used over the bad area. sometimes a stump will be found during excavation
Concrete Basement floor Fill & Level Crispy Building & Construction 4 11-06-2009 06:39 PM
Ceramic floor tile on concrete basement floor w/toilet pedestal amp2oo1 Flooring 1 10-05-2009 08:31 AM
Painting 2year old basement concrete floor gpj111 Painting 3 05-13-2009 12:01 PM
Is it ok to paint concrete floor in winter... dbldee20 Painting 2 02-06-2009 02:06 PM
