Concrete - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-13-2011, 09:25 AM   #1
concrete
I have concerns w/pouring footers this x of year!
I live just outside of Annapolis,MD
mrjohn is offline   Reply With Quote
Old 01-13-2011, 09:27 AM   #2
Rewards Points: 558
Originally Posted by mrjohn View Post
I have concernsw/pouring footers this x of year!
Please explain yourself of the problems or concerns you have so we can have a better understanding and may be able to shed some light on your problem.
epson is offline   Reply With Quote
The Following User Says Thank You to epson For This Useful Post:
mrjohn (01-13-2011)
Old 01-13-2011, 10:12 AM   #3
concretemasonry's Avatar
Rewards Points: 2,594
They just started digging on a job (basement) yesterday about 2 blocks down the street when the temperature was -5F and will be done in 4 days and ready for capping and framing.
It all depends on what you are pouring and how much planning and protection, you want to do. - In other words more information
Dick
concretemasonry is offline   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
tpolk (01-13-2011)
Old 01-13-2011, 10:41 AM   #4
My main concerns is the weather footers are for porch and kit bump out dropping down into the 20' at nite
Old 01-13-2011, 11:45 AM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,078
Ayuh,... Pour earlier in the day, use hot water for the mix, then after it's struck off, fininshed, 'n tightened up,...
Insulate it with plastic sheeting, blankets, hay bales, whatever it takes...
The concrete will be makin' it's own Heat, ya just gotta slow it from loosin' that heat...
The Following User Says Thank You to Bondo For This Useful Post:
mrjohn (01-13-2011)
Old 01-13-2011, 03:19 PM   #6
If it is only 20F (not really cold since it is air temperature and not concrete temperature) at night and it is enclosed/protected, you should have no problem. Footers for a porch usually have little load and by the time you have a load on them, the concrete footers will be stronger than anything above. That is part of the prescriptive standards that are the minimums in residential codes.
As long as you are not pouring on realy frozen soil, just pour and protect for a few days. Then you can backfill and use Mother Nature and the thermal storage of the soil to protect the concrete.
Dick
mrjohn (01-13-2011)
Old 01-13-2011, 03:46 PM   #7
Owner
LateralConcepts's Avatar
Don't forget to locate underground utilities (i.e. sewer or septic lines, tanks, or drainfields) before pouring whatever you're pouring. Wouldn't wanna pour concrete over something that may need to be accessible later.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
The Following User Says Thank You to LateralConcepts For This Useful Post:
mrjohn (01-13-2011)
Old 01-13-2011, 05:33 PM   #8
Thanks all I'll sleep well 2 nite LOL
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 04:53 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 08:21 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
