Concord Furnace Problems/troubleshooting - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-30-2011, 04:35 PM   #1
Concord furnace problems/troubleshooting
Hey guys,thanks in advance for looking at my issue- just had a new furnace installed- heats only one side of house really well!{lol} when furnace fires and I feel the ducts @ phlenum heat is directed only one way-other direction ducts are cool to touch- any ideas?
warren123 is offline   Reply With Quote
Old 12-30-2011, 04:40 PM   #2
Rewards Points: 582
picture would help maybe a damper in ductwork sending air to only one side???
Old 12-30-2011, 06:18 PM   #3
I'm Your Huckleberry
Rewards Points: 2,270
Is this a horizontal or vertical furnace? Does the new transition, if you have one and it's new, match both the furnace and evaporator coil openings or is it too small or too big and blanked off?
I'd have to assume, as Ben has said, a damper is most likely the culprit but check the transition.
Yes, pics would help greatly.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 12-30-2011, 07:02 PM   #4
biggles's Avatar
follow the supply duct from the furnace when it splits like a pair of pants legs stop there is a direction balancing damper full over to the heated side adjust it back...the heated section is blasting air out....
Old 12-31-2011, 04:40 PM   #5
Red face
furnace problems
Hey guys thanks for quick reply- I asked the furnace guy if he could put a damper in the one side so that all of the heat wont go that direction- but as of yet there is no damper installed on ducts- it is a vertical unit- does this maybe have a damper in the furnace itself, because there is none on ductwork!
Old 12-31-2011, 04:42 PM   #6
You could possibly have dampers on the plenum where the duct takes off from the unit.
Thanks.
Concord 90 + high efficiency gas furnace ahamerik HVAC 4 09-20-2011 10:35 AM
New Furnace Install AustinPorsche HVAC 1 05-12-2011 10:16 PM
Concord 90 Plus Gas Furnace Problems turby HVAC 4 11-08-2010 07:38 PM
Help! with Concord 80+ gas furnace + T-STAT joryeln HVAC 0 09-16-2009 12:23 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
