Concerned About Deep Hairline Cracks - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-16-2009, 07:47 PM   #1
I'm new to this forum and am not technically minded at all when it comes to DIY etc, so please excuse me if I sound like a complete fool by asking this question..! I've tried using the search function, but couldn't find an answer that way.
I live on the fifth floor of an apartment building and it's recently come to my attention that there are quite a few long, and seemingly deep, hairline cracks on the ceiling of my apartment. Some are two or three feet long and I'm able to slide a straigntened paper-clip the entire way in - so they're at least a few inches deep and possibly a lot deeper. Some are found above doorways, others emerge from the corners of what I can only assume are support columns?
I will mention it to the management of the building, but I'm not at all concerned about the asthetic side, more the safety of the building. Should a building only about 5 years old have such things? They're not only in my apartment, but in the public areas like the lobbies too.
Any input greatfully received!!!
jecop is offline   Reply With Quote
Old 04-16-2009, 07:53 PM   #2
Five Star's Avatar
are you in a earth quake zone?
post a location it might help!
Five Star is offline   Reply With Quote
Old 04-16-2009, 08:03 PM   #3
I actually live in Ireland so it can't be quakes.... although you mentioning quakes in connection with these cracks has me suitably alarmed...!
As far as I'm aware the last quake we had here was offshore in the mid 1980s!
Old 04-16-2009, 08:19 PM   #4
Five Star's Avatar
could be that it was never adressed how old is the building..?
i would talk to some neighbors and see if they have similar cracking in there apartments!
Old 04-16-2009, 08:30 PM   #5
The building is about 5 years old. 6 at the most. I don't know anyone else in the building and I'm a bit reluctant to walk up to a stranger and ask about their cracks.
Having said that though, there are definitely signs of similar cracks elsewhere in the building.
Old 04-16-2009, 08:42 PM   #6
Five Star's Avatar
if you rent, then i would start looking for a new place.
if you own,then go talk to your building super,association,and neighbors,or building department.
good luck
Old 04-16-2009, 10:49 PM   #7
Registered User
Rewards Points: 4,900
If a wood-frame building, they sound like normal settling cracks. During the season changes the wood settles, causing small cracks in the texture at the wallboard joints and in the paint. If they installed the wallboard with a joint directly above the window or door jamb improperly, a crack will show there. If the cracks are in a straight line, it's a joint. If crooked, and not plaster walls, I would be concerned. Be safe, GBAR
Gary in WA is online now   Reply With Quote
Old 04-17-2009, 05:39 AM   #8
Thanks for all your responses.
Most of the cracks are straight, but there is one over the bathroom door frame which is "staggered" in a diagonal fashion. Like a side profile of a staircase, if you know what I mean.
Unfortunately, I've no idea if the building is woodframe/plaster walls etc. Like I said in my opening post, I'm really not knowledgable on such things at all. I'm a bit worried about getting laughed at when I bring this to the attention of the management but I guess I've no choice. I just needed some info from people like yourselves so I don't sound like a complete idiot!
I should be able to talk to someone about things on Saturday. I'll post an update when I get more info.
Thanks again!
Repairing Hairline Cracks in Plaster Walls jerome8283 Painting 8 11-17-2011 08:43 AM
Advice needed for filling large basement Cracks dgbehrends Building & Construction 11 11-17-2009 05:23 AM
using caulk instead of tape on hairline cracks.. windowguy Painting 2 04-15-2009 11:27 PM
Window Glazing - hairline cracks bill3752 Painting 3 10-04-2008 12:15 AM
Hairline Cracks after painting parasailing Painting 8 07-24-2006 12:47 AM
