-   -   Compression joints (http://www.diychatroom.com/f2/compression-joints-75414/)
ab56452001 07-05-2010 04:10 AM
Compression joints
Hi , some compression joiners have a copper olive , some a nylon one some rubber , which is better , ta......
Just Bill 07-05-2010 06:14 AM
The brass ferrule is for copper pipe, nylon is for plastic pipe, rubber not recommended.
ab56452001 07-05-2010 08:23 AM
Thanks for reply , had an emergency job , had to put on pipe caps , dribled with metal ferules , had a few rubber ones and ( walla ) , caps on tight no leaks , now gotta work out how to proceed tommorow.
Just Bill 07-06-2010 06:10 AM
Brass ferrules require more tightening pressure to finally seal tightly. I often grease the fitting with plumbers grease to allow things to tighten easier.
MagicalHome 07-11-2010 02:09 AM
Hello, why shouldn't we use rubber???
Hi! Please tell me why we shouldn't use rubber????
Just Bill 07-11-2010 06:50 AM
Rubber tends to harden and crack over time. In some places they work just fine, in some I prefer not to use them.
