Composite Versed Plastic Deck Material - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-14-2007, 03:15 PM   #1
composite versed plastic deck material
-need to replace a very large deck and railings that are 14 years old, The initial deck was built using treated wood.
Is the composite stuff worth the price as I live in a high mildew area and have heard that this stuff does absorb moisture and looks pretty bad in a relatively short period of time?
Is the other stuff any better as I have heard that expansion is an issue and it becomes very brittle with direct UV exposure?
If you have used either of these products for any length of time, please let me know what you think. Thanks in advance.
winx40
winx40 is offline   Reply With Quote
Old 09-14-2007, 03:59 PM   #2
Check out contractortalk.com, there is a lot of information over there on the subject.
Concordseeker is offline   Reply With Quote
Old 09-14-2007, 06:50 PM   #3
robertcdf's Avatar
Correct Deck CX is your answer... Goto http://correctdeck.com and request a sample... Let it weather for a couple months along with the other crap out there and you will see that Correct Deck CX is the best.
robertcdf is offline   Reply With Quote
Old 09-14-2007, 08:25 PM   #4
They make vynil hanrail systems. They might be a good choice for you.
jiggyjack is offline   Reply With Quote
Old 09-14-2007, 09:28 PM   #5
Tired, Cold, and Damp
slickshift's Avatar
The composite stuff isn't a mold magnet or anything
But for some reason people think it won't get mold/mildew, and are shocked when it does
It will still mold/mildew if it's in a high mold/mildew area
And wood with a quality finish will also....but it might take longer than bare wood or composte
Either one...vinyl too (it'll mold/mildew up also), will need regular anti-m/m maint. in that type of environment
slickshift is offline   Reply With Quote
Old 09-15-2007, 08:14 AM   #6
Deck Staining Pro
bigchaz's Avatar
what spacing do you have on your joists? If it was previously pt and youve got 18" o.c you may have problems with certain brands
Charlie Soden
Apex DeckSavers
NC Deck Powerwashing, Deck Cleaning and Staining
"Bringing New life to Old Wood"
bigchaz is offline   Reply With Quote
Roof used as a deck - what is a good approach rogersor Roofing/Siding 3 09-19-2007 02:05 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 08:12 PM
Deck Material ekr Building & Construction 1 05-20-2007 11:09 PM
Composite Deck penaddict Building & Construction 7 03-17-2006 11:35 PM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 08:41 PM
