Commercial Soundproofing - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-16-2012, 05:32 PM   #1
I have a commercial office with soundproofed wall and suspended ceiling. Above the suspended ceilign is a 3' high area where knee walls were built, insulated, drywalled and taped for soundproofing. However there are many voids around ducts and below knee walls where sound is escaping to other rooms.
Im planning on using roxul right on top of the suspended ceiling but am worried about covering lights (fire? although roxul is fire resistant) and open grills in the ceiling. Are the open grills used as a return air? Air entering the room comes in ducts.
Any help would be appreciated.
ordonyez is offline   Reply With Quote
Old 03-16-2012, 07:59 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by ordonyez View Post
...there are many voids around ducts and below knee walls
Unless you OWN the space don't do anything more than to seal those gaps.
Fire stop caulk and aluminum faced duct tape. No more.
Old 03-16-2012, 09:43 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Talk to (ask those questions) at your local Building Dept & Inspectional services.
There are many factors and commercial codes that can be affected, as the previous poster stated.
Commercial and multi-unit codes are NOT the same as residential codes.
In addition, you can insulate all you want to try and reduce sound, but it can, and will, travel through anything metal, anything loose and unsecured within walls & ceilings, including other utility lines and certain installed materials.
"Sound-proofing" is a misnomer. Most building materials will transfer sound. The thought process is to reduce sound transmittance = "sound reduction". That is most often done by creating "layers" of materials that can act as chambers or baffles, which change the way sound waves travel.
BTW - Ruxol is fire resistant and can be placed in contact with duct-work, lighting, chimneys, etc.
More Information Here: http://www.roxul.com/home
- Build Well -
Old 03-17-2012, 07:48 AM   #4
Soundproofing Guy
Rewards Points: 158
I think you have some good replies here. Generally ceilings lack mass. Some place drywall squares above the ceiling grid on the back of the existing tile
Ted White is offline   Reply With Quote
Heating and AC size for old downtown commercial bldg Grizzlybare HVAC 9 02-24-2011 06:05 AM
Soundproofing a common wall in semi-detached RichS30 Building & Construction 5 03-16-2010 11:04 AM
Residential vs. Commercial Ballast. Gronon Electrical 3 02-21-2010 04:13 AM
Commercial plumbing question Sasha2000 Plumbing 3 06-20-2009 04:12 AM
Commercial Ballast for Residential ???? lanyard_loop Electrical 4 11-11-2008 02:52 PM
