Cold Sunroom - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-07-2010, 11:08 PM   #1
Cold Sunroom
I live in Ontario Canada and have an existing sunroom overtop an open carport. There is no heat that goes directly into this sunroom but I could do this easily. The sunrooms 15 windows are old but in good shape single pane wood sash with single pane storm windows on the outside. I was thinking of reinsulating the Sunroom floor with spray insulation and installing new vinyl windows. I use this for a cottage so I am there just on weekends and every other weekend in the winter. Right now I just have this area sealed off.
Questions
Am I proceeding in the right direction ?
Will this help with the loss of heat ?
Is it worth the money ?
alphamale1 is offline   Reply With Quote
Old 01-08-2010, 07:48 AM   #2
Rewards Points: 5,336
If it's not heated, new windows and insulation won't make it too much warmer. You'll experience some solar heat gain, but the new windows are made to reduce heat gain through coatings to the glass.
New windows, insulation and heat will do the trick.
Ron
Cold air return questions ekulrenlig HVAC 19 10-09-2009 02:44 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 11:29 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
