Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 11-10-2010, 03:08 PM   #1
Cold Room Insulation
I have a cold room below my computer room. The computer room gets very chilly when winter sets in. The cold room is just for storage and for our septic pump. There is no insulation in the ceiling/floor. The ceiling has 5 joists. Would it be best to "Butt" the styrafoam insulation between the joists or nail the insulation to the joist itself? Several different pieces of advise I have been given. And no i am not handy and need an expert answer.
Thanks guys!
Don
dgoosen1964 is offline   Reply With Quote
Old 11-10-2010, 04:55 PM   #2
I'd fill the joist bays and sheetrock over it. This would be code as the foam board will give off gases when burned.
Ron
Old 11-10-2010, 10:14 PM   #3
I, too, would sure sheet rock, and I'd use the ADA (airtight drywall approach) to help keep any air/moisture sneaking into your insulation. Whatever batt insulation you use, avoid fiberglass if at all possible. Use cotton or cellulose (treated w/ borates) or mineral wool.Fiberglass batts are really not very good insulation, and installing them overhead is not good for eyes, lungs, and skin, IMO. I hate that stuff w/ a passion.
Insulation anxiety jbatl Building & Construction 0 06-06-2010 11:14 PM
Vents from boiler room RammsteinNicCage HVAC 3 03-11-2009 08:28 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
help me solve this mystery please lindaberrien Roofing 17 06-12-2007 02:06 AM
What is cold room for? KUIPORNG Remodeling 4 04-26-2007 06:06 PM
