Cold Floor Around Windows. - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-12-2011, 09:53 PM   #1
Cold floor around windows.
Hello,
The floor surrounding our windows gets extremly cold in the winter and was wondering if anyone has any suggestions. There is a basement underneath. Should I just shove some insulation under the floor? Don't really have money to call in a professional. Thank you.
Mike
believeland is offline   Reply With Quote
Old 01-12-2011, 10:05 PM   #2
Rewards Points: 324
Are the rim joists underneath it sealed and insulated?
gma2rjc is online now   Reply With Quote
Old 01-12-2011, 10:12 PM   #3
No, its an older house. The basement has no ceiling and looks like nothing is insulated.
Old 01-12-2011, 10:19 PM   #4
Also the windows have window boxes the come away from the house a bit.
Old 01-13-2011, 08:45 AM   #5
Rewards Points: 6,652
You want the basement to breathe, especially if you do not have a fresh air intake for the Furnace & Water Heater. Just placing R-13 or R-19 kraft faced batts into the Joist bays & Rim joist bays around the perimeter of the basement is enough to stop cold air. Just make sure that you seal any openings with Great Stuff foam or Caulk. You can go a step further by sealing with XPS foam board, and placing foam board on the walls in your basement to help not only place a Vapor Barrier on the walls, but also to help stop the Convection process.
Old 01-13-2011, 08:46 AM   #6
The window boxes have nothing to do with the cold. If your walls are air tight, but no insulation, the air space helps to insulate the wall space, but having insulation in the walls & along the basement upper wall perimeters helps stop the convection process.
Old 01-13-2011, 01:48 PM   #7
Thank you all for your help. I'm guessing you can buy these products at lowe's or somewhere like that. If not ill figure it out. Thanks again.
Pella Windows - Serious Frost Issue snowman72 General DIY Discussions 22 07-08-2011 01:39 AM
replacing windows.. modifying a rough opening by less than 2 inches? diy'er on LI Building & Construction 14 09-18-2010 07:43 PM
Replacing windows from the inside RosenKen Remodeling 3 08-06-2009 01:27 PM
Replacing aluminum frame windows gallasm Remodeling 2 01-05-2009 11:03 AM
