Cold Air - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-15-2012, 04:34 PM   #1
Cold Air
I have cold air coming up in a room from the corner of my house, leaving moisture going up the wall.I just replaced the trim in the room and 2 weeks later the nails were showing signs of rust in that corner. The foundation is block, is the vapor barrier on the outside broken or is the wood rotten or is the foundation comprimised. Not a good arrangement. My questin is simple where should I start without destroying the laundry room , ripping half the siding off and without making my wife shake her head,saying I thought you new what your doing
Thank-you
Mike
mmhazel is offline   Reply With Quote
Old 01-15-2012, 06:39 PM   #2
Rewards Points: 6,652
Really need pictures.
Old 01-16-2012, 06:24 AM   #3
It could be:
no insulation at the corner studs, air gaps at the sill plates or wall plates, gap around framing in general.
Often, a bit of non-expanding foam, or caulk, will fix the problem. That expanding foam can push things apart, so it is not recommended. For a guaranteed diagnosis, get an infrared picture of the corner. It will pinpoint the problem.
Old 01-16-2012, 07:02 AM   #4
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Sounds like the siding was installed wrong allowing water to get in. Does this only happen after a rain?
Just tell the Mrs. it's normal to do things twice.
titanoman is offline   Reply With Quote
Old 01-16-2012, 02:28 PM   #5
Rewards Points: 1,092
Sorry, but it sure sounds like you have some tearing up to do. There are too many possibilities, as mentioned. Start digging in, and when you button it up again, be sure to insulate as well as you can and AIR SEAL.
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Hot Water Turning Cold - Could it be the washer/dryer? kissiffer4 Plumbing 3 01-28-2010 04:47 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 10:29 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 08:05 AM
