Coice Of Wood For Table - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-19-2010, 02:27 PM   #1
Coice of wood for table
Hello woodworkers
I am building a side table(about 7' by 20") for dining room which already has a walnut table and chest which I built. I would say my skills are middle of the road. Everything I have done to date is either walnut or cherry.
Wood choices I have been considering are mahagony, Blood wood, sapelli, walnut and bubinga. (Excuse the spelling if it's wrong.) All but walnut are locally available in sizes that woul allow the top to be one piece.
I would like there to be interesting grain patterns, for the wood to be somewhat easy (or at least not near impossible) to work. I don't know these woods at all but have been informed that bloodwood is uniform in grain pattern, that bubinga has a grain pattern which may cause pulling out if hand planed. Mahagony i think of as easy to work but with uniform grain pattern and thus possibly not so interesting.
Because the available planks are so large I am also concerned that they will split on the ends if cut.
I will be very interested in others' comments.
Thanks.
Snickerboa
Ryan Ostebo is offline   Reply With Quote
Old 02-19-2010, 02:29 PM   #2
Too Short? Cut it Again!
I would post this question to the woodworking forum. There is a link at the bottom of the page but here is the link if I copied it correctly.
http://www.woodworkingtalk.com/
Could you click on your username and update your basic location when you are thinking about it? It helps with comments to know where people are.
Old 02-19-2010, 02:36 PM   #3
Rewards Points: 5,336
For a 20" table I would use multiply 1x8 pieces. One piece would have a tendency to cup and split.
For the 3 piece setup, you would alternate the growth rings for the top to minimize the cupping aspect. If you've been building furniture, you know about the moisture factor already.
Ron
Old 02-19-2010, 03:42 PM   #4
Civil Engineer
Rewards Points: 4,522
True mahogany is very hard. Much of what is claimed to be mahogany is not mahogany at all, for example Phillippine mahogany is an unrelated species. Bubinga is also quite hard. All of the woods you mentioned except for walnut are relatively rare, usually quite expensive, and come from (likely endangered) rain forest. If that concerns you at all, you might consider going back to cherry or walnut, both of which are US products, and not particularly rare, but in my opinion are just as attractive as any tropical hardwood. Myself, I build most of my furniture from cherry, and in the kitchen I used maple.
As for the previous comment, I agree, building a table top out of a 20 inch wide board is almost certainly going to lead to warping. If you had a wide board, you could of course cut it into thirds, adjust the growth rings, and glue it up. For true mahogany, I believe you will need a different type of glue than the typical woodworkers glue, best to check with a knowledgeable supplier if you go that route.
Daniel Holzman is online now   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 05:30 AM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
