Code Compliance: Vent Dryer To Code - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-22-2013, 08:43 PM   #16
Rewards Points: 6,652
paintdrying, it is actually all over the board. Some places are stating 5 feet for a 90, another is 5-9. The site I linked to which I would trust more, is stating 15 feet for a 90 degree el. I would go with the last, just to be safe. I think that it is the 45 degree el's that are considered 5 feet of pipe run equal to.
Old 01-22-2013, 09:51 PM   #17
this has distances for both smooth and ribbed pipe and different exterior vents
http://www.askthebuilder.com/clothes-dryer-vent-tables/
Old 01-22-2013, 10:06 PM   #18
Originally Posted by gregzoll View Post
Actually incorrect. Each elbow is 15 feet, so in reality with change in measurements, you are talking around 72 feet of run. Here you go for a reference. http://www.dryer-ell.com/dryer_vent_...comparison.htm
i get it now. In that reference it says one 90 degree elbow equals 5 ft, while the 45 degree angle equals 2.5, that is the minimum to meet code. the 15 foot = 1 90degree elbow is just a "study" that was done. seems like they just want you to buy their product. I'm going to stick to minimum.
so it looks like i can get by with 8 foot straight run going up then one 45 degree elbow(equaling to 2.5 ft), a 2 foot straight run following the 45 degree elbow. After the 2 ft straight run follows another 45 elbow (2.5 ft) into a 7 ft straight run going outside.
8+2.5+2+2.5+7=22ft.
also Should i keep that black insulation on the end of the run or does that not matter?
jclee is offline   Reply With Quote
Old 01-23-2013, 01:30 AM   #19
JOATMON
ddawg16's Avatar
Rewards Points: 1,984
Code in my area....14' with no more than 2 90's.
If you have 'any' flex, then no more than 6'.
So, yes....your way over.
Old 01-23-2013, 09:40 AM   #20
when does the run actually begin. does it begin out of the dryer box, or does it begin out of the dryer machine
if it does start out of the machine, then do we have to factor another 90 degree angle
Old 01-23-2013, 09:44 AM   #21
Rewards Points: 120
"The run" is inclusive of the very first elbow or straight piece that you attach to the dryer.
Old 01-23-2013, 12:25 PM   #22
JOATMON
ddawg16's Avatar
Starts at the dryer....and because you have that flex....your maximum run is 6'.....get rid of the flex....
Old 01-23-2013, 02:00 PM   #23
Next dryer vent I am going to run I will call the inspector. Shorter the better, sounding like it is what the inspector will want to see.
paintdrying is offline   Reply With Quote
Old 01-23-2013, 02:12 PM   #24
Rewards Points: 3,130
Good plan. But I've never heard of a permit and inspection being required for a dryer duct.
Old 01-23-2013, 03:33 PM   #25
PoleCat's Avatar
Rewards Points: 1,652
We keep the washer and dryer on the front porch here to avoid just such a conundrum.
PoleCat is offline   Reply With Quote
How to vent dryer when rim joist is close to ground LucknowPaul Appliances 6 08-07-2012 07:24 AM
Dryer vent cleaning...what to look for when finding a professional quality job? imola ghost HVAC 1 07-29-2012 03:27 PM
very clogged dryer vent. Not just lint catman Tools 4 04-20-2009 04:48 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 04:26 PM
Dryer vent. kcrossley2 Plumbing 10 02-20-2008 12:02 AM
