Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 03-05-2008, 03:52 PM   #1
Coal in Woodstove
anyone ever hear of burning coal in a woodstove? will it hurt the stove?
econdave is offline   Reply With Quote
Old 03-05-2008, 04:03 PM   #2
Master General ReEngineer
Bondo's Avatar
Coal in Woodstove
Ayuh,...
Coal fires,+ Wood fires are 2 very different things,......
Burning Coal in a woodstove usually Doesn't work very well,....
And,...
While burning Wood in a Coalstove will work,.. The firebox is Soo Small,....
It really doesn't work out so well either.....
Old 03-05-2008, 07:46 PM   #3
Coal in Woodstove
i used to have a combination coal..oil..and wood stove however the model i had did not use firebrick alone...it had a 1/4 stainless steel liner in front of the fire brick (next to the coal)
it was a newmack stove and the dealer said the coal models had this as fire brick could not take the extra heat of the coal
true or not?.....i am not sure , but i had no reason to doubt the dealer
billie_t is offline   Reply With Quote
Old 03-05-2008, 07:57 PM   #4
Remodeler
MinConst's Avatar
Coal in Woodstove
Coal burns much hotter than wood. Do not burn coal in a wood stove.
Minichillo's Construction
I will never leave you hanging!
MinConst is offline   Reply With Quote
Old 03-06-2008, 07:26 AM   #5
gravity always wins
Coal in Woodstove
Coal stoves have grates to allow air to draft through it. I'd think without them you'd have a tough time keeping it burning or at least controlling it.
Old 03-06-2008, 09:08 AM   #6
When is fishing season?
CowboyAndy's Avatar
Coal in Woodstove
I have been looking at wood furnaces for the last week, and have seen a few that claim you can burn both.
http://www.vogelzang.com/Norseman2500.htm
This one in particular says you can use both wood and bituminous coal.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 03-06-2008, 04:12 PM   #7
J Calvin Construction
jcalvin's Avatar
Coal in Woodstove
Some brands of stoves will allow you different types of fuels. Don't use anything other than what the manufacturer suggests. As MinConst stated, coal burn much hotter than wood. Some report that coal can burn as much as four times the temp of wood. I wouldn't want to be the one the had molten metal running though my living room.
Cal
You hired WHO?
jcalvin is offline   Reply With Quote
Old 03-07-2008, 06:55 AM   #8
Coal in Woodstove
thanks, i was talking to a guy and he said if you have a real good bed of hot coals, just put a few pieces of say egg coal in to enhance the fire, not load it up and get it roaring. I am skeptical about doing it so I wont..
Old 03-07-2008, 08:17 AM   #9
Remodeler
MinConst's Avatar
Coal in Woodstove
Good decision.
Old 03-09-2008, 12:10 AM   #10
Coal in Woodstove
you could use some coal but i wouldnt pile it full as some one said coal burns a lot hotter than wood. only differance in the stoves the coal stove is built heaver to stand the heat. its not going to blow ur stove up to use some coal if you have coal i would use it a lil at time to help keep the fire going
js2743 is offline   Reply With Quote
Old 03-09-2008, 08:18 AM   #11
Coal in Woodstove
thanks js, thats what this guy i was talking to was saying, dont load the stove, just a few egg sized chunks at a time and that would give some extra heat. He said only add it if you have a real good bed of hot coals. Might crack the firebrick if you dont have a good bed.
Old 03-11-2008, 02:21 PM   #12
Coal in Woodstove
Unless it is meant fro coal (or both) dont put coal in it. Go to http://www.hearth.com/econtent/index.php/forums/ for guys who talk about stoves as much as you all talk about DIY stuff.
pcampbell is offline   Reply With Quote
painting a woodstove JAVAMAN Painting 7 05-12-2009 07:47 AM
woodstove insert JAVAMAN General Discussion 5 12-05-2007 09:00 PM
woodstove JAVAMAN General Discussion 1 12-05-2007 03:31 PM
Coal Stove Hood Devil505 HVAC 1 12-06-2006 06:32 PM
converting coal boiler teresa17603 HVAC 6 10-25-2006 01:46 AM
