Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 07-18-2010, 04:58 PM   #1
Cloth inside walls
Whats up guys-
I have an older house, just opened up one of the walls. Any idea what this heavy duty type cloth is that is stapled to the studs? Cavities are empty. I'm wondering if it serves a purpose or is some type of primitive insulation?
Thanks!
-Greg
http://i746.photobucket.com/albums/x...b/DSC00109.jpg
c00rdb is offline   Reply With Quote
Old 07-18-2010, 05:52 PM   #2
Xtreme DIY'r
Cloth inside walls
Where are you located ?
Old 07-18-2010, 07:09 PM   #3
Cloth inside walls
Looks like canvas. Maybe it was a houseboat in a previous life.
I can't see any point in keeping it in place.
Ron
Old 07-18-2010, 08:53 PM   #4
Moderator
Cloth inside walls
It may be the outside cloth they used with pipe insulation containing asbestos. Are the pieces of uniform width? Like the circumference of a 3" or 6" water pipe? Maybe a plumber owned the house... I hope it's only as Ron said.
I hope those are only ceiling joists above......
Be safe, Gary
Clothes taking longer to dry?
Old 07-19-2010, 10:16 AM   #5
Cloth inside walls
I'm located in NJ. I hope its not asbestos! It just has the feel and look of canvas fabric, I guess I'll throw on my respirator and use the HEPA filter on the shop vac to clean up anything.
What you see above is some blocking that was used for a drop ceiling, followed by an older ceiling above it, and the joists are above that. Problem is that the canvas is attached behind the blocking so I'd have to take it all down to remove it all. That or just cut it like I was planning to do. If there's a possibility there is asbestos though I guess I'd be better off taking down the blocking.
Old 07-19-2010, 12:48 PM   #6
Moderator
Cloth inside walls
Don't get upset yet.... I thought maybe. Wait for other posters like an older plumber that worked with the wrap. (Older than me- 62). Don't disturb any more than necessary, keep the fibers out of the air. It may be canvas, though pipe insulation in a wall sounds more likely.... If not an exterior wall, I would say the chances are slim.
Be safe, Gary
Old 07-19-2010, 01:46 PM   #7
Totally screwed together
Cloth inside walls
Get it wet before you dink with it.
xxPaulCPxx is offline   Reply With Quote
Old 07-19-2010, 02:03 PM   #8
Household Handyman
Cloth inside walls
I've seen something similar in homes here in S. GA. which were built before, say the 1940's. And, I've only seen it on what would have been "upper-class" homes. What was behind the plaster walls here was a thick brown paper, not canvas material. The first that I saw, I was amazed that it had stood up for so many years behind the plaster as it did. One theory offered to me by an older man was that it may have been used to reduce drafts, made sense to me. David
Old 07-20-2010, 11:46 PM   #9
Cloth inside walls
It was used to slow down drafts. A friend had it in his house, built about 1900. It was fastened to the inside of the 1/2 x 4" boards. Wallpaper was the next layer. But my 1890 house has no fabric. But I have plaster.
fireguy is offline   Reply With Quote
Old 07-27-2010, 02:35 AM   #10
Cloth inside walls
It looks like canvas to me. Is that some sort of an insulation? Maybe it was used as a divider when the walls are not yet built. Just a thought.
MagicalHome is offline   Reply With Quote
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Using OSB on inside walls handymanII Building & Construction 8 03-23-2010 09:24 PM
condensation inside walls jusolson Building & Construction 2 02-16-2010 09:19 AM
adding insulation to inside of exterior walls darylbe Building & Construction 4 02-01-2010 09:18 PM
Help please...quick. Kilz dripping off walls jenllo Painting 7 01-24-2010 08:40 PM
