Closing Crawlspace Vents -- Temporarily - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-09-2009, 12:50 AM   #1
Closing Crawlspace Vents -- temporarily
my house in Northern California was finished in ~1999 and has a perimeter foundation. The crawlspace is clean and is roughly 3' from the bottom of joists. With the very cold nights recently, i am wondering if i can close the crawlspace vents (~3.5" X 13") with rigid insulation for a month or so. what do you think? This should keep my house a bit warmer.
Steve Burke is offline   Reply With Quote
Old 12-09-2009, 12:56 AM   #2
Wood Butcher
robin303's Avatar
I don't see why not. Just use cardboard cut to fit. Is there any moisture or mold.
robin303 is offline   Reply With Quote
Old 12-09-2009, 06:28 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
Mine have shutters that slide closed for winter. Just remember to reopen them in warmer weather.
Old 12-09-2009, 06:31 AM   #4
I would not use cardboard - if moist mold will grow
Rigid will work
Old 12-09-2009, 06:41 AM   #5
Too Short? Cut it Again!
As a former Northern California dweller I know the feeling but the vents are there for an important reason and I would not close them off.
Old 12-09-2009, 07:01 AM   #6
if i got it right, the vents are there to prevent mold. the crawlspace is dry and not moist, particularly in the winter. so i am inclined to put rigid insulation "stoppers" on the vents from late Nov thru Feb.
Old 12-09-2009, 07:03 AM   #7
Rewards Points: 582
If your climate is damp like ours, the vents are really important to keep the M/C of the timber below 20%, when dry rot will attack the flooring.
Most of the floors I have seen over the years where the vents have become blocked have had rotten floors.
However it might be OK for a month or two, but I wouldn't like to say for sure.
stuart45 is offline   Reply With Quote
Old 12-09-2009, 07:03 AM   #8
Many vents sold & installed are auto-closing in colder Temps
Its done all the time
Closing Vents to unused rooms rguerra HVAC 0 07-04-2009 10:19 PM
Closing room vents radtek HVAC 8 05-15-2009 05:16 AM
crawlspace exposed to outside and damp djbauda Building & Construction 5 07-30-2007 07:49 AM
closing vents in unused living space scottydel HVAC 1 12-05-2006 01:39 PM
