Closet System - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-05-2009, 02:43 PM   #1
Closet System
I'm going to be installing a closet system in a new master bedroom closet. Should I do this first and have my carpet work around it or carpet first and have my system installed on it?
Thanks.
hollyrock is offline   Reply With Quote
Old 04-05-2009, 07:30 PM   #2
Remodeling Contractor
If some units will be installed on the floor, then do this first and allow the carpets to be cut around them. Otherwise you cannot remove the carpet easily latter on.
Old 04-12-2009, 04:03 PM   #3
I think you should carpet it first and then you can easily installed the system on it.
kferr is offline   Reply With Quote
Old 04-13-2009, 07:24 AM   #4
Rewards Points: 356
Maybe you could build a 2 or 3 inch high raised floor under the closet system. It would give it a nice defined finished look and allow a straight edge for the carpet? Personally I would not put the closet system on the carpet unless it was easily removable.
RegeSullivan is offline   Reply With Quote
Burnham Series 2 Cast Iron Radiator System SybrDave HVAC 2 12-10-2009 05:24 AM
Hot Water Heating System in older house GrannyAnnie HVAC 2 08-31-2008 04:50 AM
Hardwood closet threshold question DIY-Renovator Flooring 1 07-27-2008 04:42 AM
Musty smell from closet after leak Musty General DIY Discussions 2 09-10-2007 08:36 PM
Size A/C system properly 70stang HVAC 1 03-26-2006 07:22 PM
