Closet Rod - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-12-2012, 11:36 PM   #1
Rewards Points: 208
Closet Rod
i'm looking for a new closet rod. what would you recommend? i like this white one, but i'm not sure if the white coating will chip off over time?
http://www.homedepot.com/buy/storage...rod-99759.html
Scully is offline   Reply With Quote
Old 02-13-2012, 12:02 AM   #2
Rewards Points: 13,458
There not all that strong, I would add a center support. The finish will hold up longer then a painted rod.
Want it stronger so no center support is need then go with galvinized pipe or wooden closet pole material.
Old 02-13-2012, 05:45 AM   #3
DIY staff
Rewards Points: 7,174
The chrome or stainless steel ones hold up well---the white ones get black marks from coat hangers.
Old 02-13-2012, 06:34 AM   #4
As long as you are in there why not consider a closet organizer system. You quadruple your storage space. IMO rubbermaid is superiour to closetmaid
creeper is offline   Reply With Quote
Old 02-13-2012, 01:03 PM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 302
1 1/4 inch electrical conduit makes a good rod also and will hold a lot of weight.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 02-13-2012, 01:51 PM   #6
Rewards Points: 6,652
PVC piping works better than that cheap closet rod. If you want to add a core, get wood dowel or insert emt inside.
Old 02-15-2012, 12:54 AM   #7
I bought a Closet-Pro adjustable metal rod with a white finish, and it's been really good. The finish is holding up fine, although I prefer thick plastic hangers over wire hangers, so that might have something to do with it. I do have some wire hangers, but it hasn't been an issue.
When I bought my metal rods, I looked at the wood dowels, as well. The dowel would have only been propane delivery san diego about a dollar or two less, and still need to be painted. The reason I was replacing the existing wood rods was because the paint was wearing off and they were warped to hell, so there was no reason for me to go with wood again and inevitably end up in the same situation down the road.
The metal rods won't sag, and I'll never need to replace them.
The tubular design of the ClosetMaid 4 ft. Super Slide Closet Rod lets hangers slide freely on the rod, offering easy hanger adjustment. The durable body holds up to 30 pounds and is constructed of steel for strength and resistance to sagging. The smooth white epoxy finish coordinates with most closet colors.
Durable steel construction prevents the rod from sagging
Tubular design lets hangers slide freely on the rod for easy hanger adjustment
White epoxy finish coordinates with most closet colors
For use with both fixed mount and Shelf Track mounting systems
MFG Brand Name : ClosetMaid
MFG Model # : 2057
MFG Part # : 2057
You can go to home depot and buy a wooden dowel rod.
Those are usually extremely strong and high rated.
JMO.
diyjohn1234 is offline   Reply With Quote
Old 02-15-2012, 10:14 AM   #8
Learning Things Every Day
Jay 78's Avatar
When I bought my metal rods, I looked at the wood dowels, as well. The dowel would have only been about a dollar or two less, and still need to be painted. The reason I was replacing the existing wood rods was because the paint was wearing off and they were warped to hell, so there was no reason for me to go with wood again and inevitably end up in the same situation down the road.
Under Construction
Jay 78 is offline   Reply With Quote
Old 02-15-2012, 06:05 PM   #9
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,116
depending on the span of the closet rod i use different rods
for short closets i use the cheap white ones. for spans over 5 ' i use heavy duty chrome rods which come from a commercial hardware supplier
woodworkbykirk is offline   Reply With Quote
Removing existing closet gnomonklater Building & Construction 4 12-02-2011 12:14 AM
Framing a new header for closet opening jmai14 Carpentry 6 07-09-2011 02:20 PM
Laundry closet decision LClark Remodeling 2 06-26-2011 06:19 AM
Hardwood closet threshold question DIY-Renovator Flooring 1 07-27-2008 04:42 AM
Musty smell from closet after leak Musty General DIY Discussions 2 09-10-2007 08:36 PM
