Closet Door Options - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-05-2011, 03:10 PM   #1
gmhammes's Avatar
Closet door options
So have have had the idea of how i want to renovate my master bedroom however recently i have been having second thoughts on how i want to do the closet.
Here are the specs.
Wall is 106" long.
It is not a walk in closet. depth is about 30-36"
Right now the current closet only utilizes 2/3 of the wall as the other 1/3 used to be an entry closet on the other side of the wall however the previous owner covered that closet up with sheetrock so it is now usable in the bedroom.
Thought's, suggestions, pictures?
Like i said, originall i had an idea however before executing it wanted to see what you all suggest.
thanx
gmhammes is offline   Reply With Quote
Old 01-05-2011, 03:28 PM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
So shouldn't YOU be providing the pictures, and US the thoughts & suggestions?
Help us help you
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 01-05-2011, 03:47 PM   #3
gmhammes's Avatar
I will get some up tonight hopefully of what currently exists.
Since you mention it, i had planned on putting 3 slab doors on a bypassing track by Johnson. However i wanted the middle door on the outside of the other two so i could install a mirror on it. This is not a expensive house and i wan tto match the doors so i am using oak tone hollow doors painted white.
Pictures to come.
6 panel bypass closet doors Steve Baumgart Carpentry 5 05-10-2013 08:52 PM
Linen Closet Lighting stubits Electrical 24 06-19-2009 11:32 PM
No-Hub Cast Iron Closet Bend / Closet Flange lazypants Plumbing 10 06-11-2009 10:48 AM
Hardwood closet threshold question DIY-Renovator Flooring 1 07-27-2008 04:42 AM
Musty smell from closet after leak Musty General DIY Discussions 2 09-10-2007 08:36 PM
