Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 10-18-2008, 08:31 PM   #1
Close off a basement window
I recently purchased an older home. I have discovered that two of my basement windows are actually plywood and also below hte soil grade. The previous owners had a cement patio poured right up to were these windows are. They are now leaking and getting into my basement. How do I close these things off permantely. I have several other basement windows that are just fine and done properly, so i will still have use of others if these two are gone.
Please Help...
mwerner is offline   Reply With Quote
Old 10-19-2008, 07:09 PM   #2
Theres more then one way.
iMisspell's Avatar
Meaning the patio slab is flush with the bottom of the window ?
And being theres dirt covering the out side of the window, you have concrete or block basement walls which these windows are in ?
Maybe you could knock out the window, block and mortar and be done with it for ever.
You might have to cut alittle of your patio slab so you can get a good seal. If you just fill in the window its possible where your new "fill" meets your current patio there will be a leak. Probably best to cut way a few inches in all directions.
Just an idea till a more knowledgeable person pops in.
iMisspell is offline   Reply With Quote
Old 10-20-2008, 08:24 AM   #3
Thanks, I really appreciate it. The patio cement is actually above the bottom of the window.
Basement Window leaking suze0220 General Discussion 8 08-06-2011 10:21 PM
DIY Egress window in basement? ClnlBrahm Building & Construction 5 09-03-2008 12:15 PM
Window in Basement almostdone Building & Construction 6 02-29-2008 12:43 PM
Want to install larger window in basement wall andrewcocke Remodeling 8 02-24-2008 11:51 PM
