Clogged Garbage Disposal - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-08-2011, 12:11 PM   #1
I have a problem with my garbage disposal. The machine itself is still working fine. When you turn it on, it brrrrr normally (i.e. it is not jammed), but water just cannot drain through it.
I have check the U piper underneath the sink, no problem there. I also checked the pipe from the disposal to the U piper, no clogging there either. That means there is clogging in/by the disposal itself.
Is there anything I can/should check about the disposal unit itself? Or does this mean I need a new one? Thanks!
Dave in Michigan is offline   Reply With Quote
Old 08-08-2011, 01:10 PM   #2
Rewards Points: 6,652
Sounds like you are feeding it too much, and the wrong stuff.
Old 08-08-2011, 01:35 PM   #3
Experienced
Jackofall1's Avatar
Remove the disposal, 1/4 turn ring where is connects to the bottom of the sink, this will give you a clear view of the chopper plate.
Mark
Connecting new dishwasher and garbage disposal -- no ground wire in the conduits. arca Electrical 17 03-28-2011 03:06 AM
Object in Garbage Disposal coolptnr Plumbing 3 05-18-2010 03:02 PM
Old garbage disposal question please help. linuxguy0481 Kitchen & Bath Remodeling 3 07-26-2009 11:03 PM
slow draining garbage disposal lchiu7 Plumbing 3 04-05-2009 04:00 PM
garbage disposal clogged amakarevic Plumbing 1 03-31-2009 02:16 PM
