Clicking Sound Under Kitchen Sink - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-01-2008, 10:36 PM   #1
Question
Clicking sound under kitchen sink
For 4 days now there is a clicking sound under my kitchen sink. It sounds like it's coming from the garbage disposal. I disconnected the plug but the noise continued. It literally goes "click,click,click" non stop.
I have a Everpure water cartidge right next to the garbage disposal but there are no moving parts in it that could account for the clicking
What could be causing the sound?
Tommy
Tommy is offline   Reply With Quote
Old 01-02-2008, 09:13 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,726
Ayuh,........
I Guess you otta just crawl down in there,+ Listen/ Look........
Old 01-02-2008, 10:54 AM   #3
Custom Cabinet Maker
Tell the damn crickets to shut up
skymaster is offline   Reply With Quote
Old 01-02-2008, 11:10 AM   #4
Home Improvement Guy
ron schenker's Avatar
Maybe a family member dropped their Timex down the sink
Tommy
ron schenker is offline   Reply With Quote
Old 01-02-2008, 11:37 AM   #5
Res Ipsa Loquitur
Plastic piping will cause this sound due to expansion and contraction. Look for plastic as drain pipes or water supply pipes. It may be rubbing against the holes in the cabinet or other pipes.
handyman78 is offline   Reply With Quote
Old 01-03-2008, 02:20 PM   #6
Thanks Handyman78 but there are no plastic pipes of any kind just copper tubing for the water filter and metal pipes for the garbage disposal.
Any other ideas please?
Tommy
Old 01-03-2008, 03:12 PM   #7
Res Ipsa Loquitur
Metal pipes can also do this but to a lesser degree. Your water filter is likely made of plastic and can have expansion issues. More info- does it happen when the water is run? Hot, cold or both? You said you unplugged the disposer which rules that out from an electrical point of view.
Have you ruled out a mouse for instance?
Rehabbing a porcelain kitchen sink guenthecat Remodeling 10 12-18-2007 10:10 AM
Clicking sound in walls leted_82 Plumbing 7 10-16-2007 06:25 AM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 10:22 AM
Kitchen sink jonnyjonny_uk Plumbing 6 11-20-2006 06:43 AM
Sink or No Sink in Kitchen Island? Not Sure Plumbing 4 08-29-2006 07:37 PM
