Cleanout Buried 2 Feet Down And Sideways - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-20-2014, 08:06 PM   #1
Cleanout buried 2 feet down and sideways
I was wondering why my sewer clean out was installed in the side of the drain instead of on top and then buried about 2 feet deep.
I discovered this when I was digging to add a clean out. Any suggestions for a simple way to make use of what's already there and get it to ground level with some extension.
jrbrooks33 is offline   Reply With Quote
Old 01-20-2014, 08:15 PM   #2
Here is a picture:
Old 01-20-2014, 08:20 PM   #3
Rewards Points: 14,306
Dig out all the way around it, cut the pipe on both sides, rotate it to where it should have been and use Two repair couplings or hub less connectors.
A repair coupling is a coupling with not raised area in the middle so it can be slipped over the pipe and slid back when cleaned and glued.
Then add a short piece of pipe and a 45,another piece of pipe and a clean out adapter.
Old 01-20-2014, 08:34 PM   #4
Thanks! Is this what I would use to connect to the existing clean out threads? Then, attach a 45 to that.
http://m.lowes.com/product?langId=-1...&nValue=SEARCH
Old 01-20-2014, 08:42 PM   #5
I made a mistake in my post.
Replace that clean out that's there now with this.
http://www.homedepot.com/p/NIBCO-4-i...HD4/100343303#
Old 01-20-2014, 09:10 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 904
It was possibly installed sideways for testing purposes, then capped after inspection
San tees are not approved as clean out fittings in all areas, I suggest a wye
Old 01-20-2014, 09:43 PM   #7
Ok thanks theEplumber that makes a little more sense. I was confused as to why they would have done that.
I was prepared to install a wye anyway when I started digging and saw this. So, sounds like I should just proceed as planned.
Old 01-21-2014, 11:15 AM   #8
Rewards Points: 372
Talking
Finally a good news thread! I just had a major plumbing success.
Hi all,
I accidently hit reply when I was planning to do a new thread.
imautoparts is offline   Reply With Quote
