-   -   cleaning up spilt pvc cement on slate table (http://www.diychatroom.com/f2/cleaning-up-spilt-pvc-cement-slate-table-108736/)
scotzilla 06-25-2011 11:01 AM
my wife bought a costco slate table. When i put it together it said it was sealed. Anyway my buddy has been helping me with some electrical on a built in bbq and the other day I came home and he had spilled some clear pvc cement on the table. It was all dried out so I quick covered it with some building materials before my wife saw it.:eek: I tried chipping at it with a screw driver but its not working out so well. ANy chemicals i can use to soften this stuff up and get it off?
please help i dont want to face the wrath of the wife:(
STL B. 06-25-2011 12:00 PM
Scrape off as much as you can then use acetone......it should work.
Ron6519 06-25-2011 12:52 PM
My guess would be you'll need new felt.
I don't know what you mean by, "When i put it together it said it was sealed." You can't seal felt.
STL B. 06-25-2011 01:03 PM
I think it's just a slate top patio table.
scotzilla 06-25-2011 01:47 PM
http://i36.photobucket.com/albums/e4...6-25104109.jpg
ill try the acetone
STL B. 06-25-2011 02:12 PM
MEK may also work.
Ron6519 06-25-2011 03:21 PM
Have no idea why I thought it was a pool table.
I'd try powerwashing it first. Less chance of a color change.
rustyjames 06-25-2011 06:21 PM
I wouldn't worry about color change with that. I would try some paint remover piled on thick. Keep it wet with the remover and shaded so the sun doesn't dry it. Pressure washing might work but it'll probably take out the grout too.
user1007 06-25-2011 06:53 PM
Freeziing and cracking it if you can keep from freezing the slate too much? Lay some dry ice on it or try one of those home wart freezing kits? Watch your hands for freezer burns. Got a friend near a lab that can get you a couple qtips full liquid nitrogen or something?
Superheating it with paint gun?
Please do not regard these as tried and proven expert approaches. I am just brainstorming ideas that might work.
Bud Cline 06-25-2011 07:52 PM
Citris paint stripper.:)
jcrack_corn 06-26-2011 02:16 PM
i would try heat gun first, i think you should be able to melt that off and use a scraper pretty easily.
if you go a chemical route, you should probably build a dam around it with plumbers putty or something and pool the chemicals over it so it stays wet.
some of the things mentioned are petroleum based solvents and will almost CERTAINLY discolor the slate.
I would try Denatured alcohol and/or acetone first...i think neither should stain the slate, and both are very nasty stuff that for whatever reason are often overlooked. Wear gloves because they will completely dry your skin out instantly.
Bud Cline 06-26-2011 02:40 PM
...and "plumbers putty" won't ???
jcrack_corn 06-28-2011 01:28 PM
right, because entrapped distillates in a solid putty form that may have minimal leaching that should be superficial is the same thing as dumping liquid petroleum distillates on porous stone.
:whistling2::thumbsup:
Bud Cline 06-28-2011 05:33 PM
WOW! Not at all following that!
In other words .................................................. ?:)
DangerMouse 06-28-2011 06:22 PM
Go get a can of clear PVC primer! (NOT PURPLE!) It'll dissolve it the best!
DM
