Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-08-2009, 03:25 PM   #1
Cleaning up /pointing brick
I deciding to expose an old chimney in our house, and the brick work was repaired pointed at some point, i believe with cement and not S mortar. The chimney is lined, and I really don't want to tear out the cement to put the right mortar.
But whoever did it did not clean off the bricks well, I started using some old sandpaper just to see and it seemed to take the cement off pretty well, as well as the top layer of dirty brick. Could I do this, and just seal the brick with some sort of polyurethane?
troyce1 is offline   Reply With Quote
Old 01-08-2009, 06:42 PM   #2
If what you're doing works, continue the process. I wouldn't use poly on the brick, though. There are masonary sealers to use, if you want it sealed.
Ron
Old 02-28-2009, 07:40 AM   #3
I have removed the plaster that covered a brick chimney that goes through the floor and ceiling of one of the rooms in our 1905 vintage house.
I'm going to clean up the bricks and then seal the whole thing, but I don't want it to be shiny. What sort of sealer would work best?
gordonw is offline   Reply With Quote
Old 02-28-2009, 07:56 AM   #4
Remodeling Contractor
go to your local mason supply house. They will have sealers that are made specifically for brick.
Old 02-28-2009, 12:56 PM   #5
20 year old Brick Wall Repair Bobrobert General Discussion 15 11-22-2011 04:07 PM
Sealing historic brick tenzo General Discussion 2 11-22-2008 04:04 PM
painting brickwork Pandi Painting 5 11-12-2008 07:46 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 08:17 AM
