Cleaning Stained Timber Stair Rails - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-04-2013, 05:49 PM   #1
Cleaning stained timber stair rails
I have stained and varnished timber stair rails in my house - 20 years old.
I have tried cleaning them with both spray polish and vinegar and water but they still feel 'sticky'
Any suggestions please on something that will take away that sticky feel?
Wandererone is offline   Reply With Quote
Old 03-04-2013, 05:54 PM   #2
Rewards Points: 13,774
I would have used several coats of poly instead of varnish.
Old 03-04-2013, 06:43 PM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Wandererone View Post
I have stained and varnished timber stair rails...
...something that will take away that sticky feel?
A light wipe with mineral spirits or even turpentine should do well.
Be prepared to then (re) coat with a good wax.
The Following User Says Thank You to TarheelTerp For This Useful Post:
oh'mike (03-04-2013)
Old 03-04-2013, 07:42 PM   #4
DIY staff
Rewards Points: 7,174
Tarheal uses the same technique as I do---a bowl of mineral spirits and some 4 o (00000 ) steel wool---
After cleaning I often use Minwax wipe on Poly to add some shine and protection---
Old 03-05-2013, 02:25 PM   #5
Well it may well be poly. I just know its shiny
Need to tighten spindles on stair rails. crescere Building & Construction 21 02-02-2013 06:21 PM
stair hand rails chulett Carpentry 30 04-10-2011 09:42 PM
Refinish pickled painted stair rails upd Painting 1 10-06-2010 09:36 AM
Cleaning Cycle Stained Stove jmed99 Appliances 1 01-27-2010 07:11 AM
Wood Finish to Stair Rails propilot5000 Painting 1 01-09-2007 06:22 PM
