Cleaning Oven Racks Help! - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-22-2011, 03:01 PM   #1
Cleaning oven racks Help!
Well here we are a brand new Fridgidaire stove and Convection oven.
Ready to self clean but the how to book says to remove the racks from the oven when self cleaning because they have a coating on the rails that prevents the racks from squealing when sliding in and out and helps slide much easier.
So I preceded to clean the racks by hand in a plastic tub filled with very hot water and soap.
Well the light colored brown substance would not budge, I became frustrated and went to my number two cleaner, a Number 00 steel wool pad, This did the trick but rubbing each wire rod with great pressure. After three racks and all those rods. I know there must be a better and easer way ?
Yes I thought of oven off cleaner, but this was after the fact!
I really don't care for chemicals unless it is of the last resort.
So if you have an easier way you can jump in any time and offer some advise.
Oh ya I asked my wife lets not put all the racks in the oven Just ones we need and when we need another just add it.
Smart " A "
Robut
robut is offline   Reply With Quote
Old 04-22-2011, 03:53 PM   #2
Too Short? Cut it Again!
Try dumping a couple cups of ammonia into a tight garbage bag. Put the racks in. Seal the bag and let it sit outside overnight. Could work.
I've never found the low temp, overnight oven cleaners to be that challenging for oven racks or even the backyard grills. You baking caramel apples without a drip pan or something?
Old 04-22-2011, 09:25 PM   #3
Smart " A "
Robut
very helpfull indeed
AmandaKennyJe is offline   Reply With Quote
Old 04-23-2011, 09:03 AM   #4
Thanks your right on!!
No Caramel baked ?
I called the stove company and a very nice woman in Tech support told me to do the exact same thing. She said she would add about 1 to 2 cups of Ammonia to a large plastic bag and store in a safe area from Children and pets for up to 48 hours
using a stiff brush would restore the racks like new,
Robut
Old 04-23-2011, 09:20 AM   #5
Rewards Points: 5,336
What is the point of this post?
Ron
Old 04-25-2011, 09:50 PM   #6
You paid for a self cleaning oven and can't clean the racks?
I clean the racks with the self cleaning feature. I also put my BBQ racks in there as well.
How much rack sliding goes on that you have to have easy sliding. Lets face it, these don't have a hundred pound of meat layin' on 'em.
Old 04-26-2011, 08:58 AM   #7
Some get so hot they will destroy the chrome finish and I suspect that is what is meant by effecting the glide. And I know they are supposed to be safe, but heating a home appliance up so hot that is just plunked in a cabinet cavity scares me as putting a high BTU commercial stove in improperly (and I see this more than I would like). I have never bought a self-cleaning oven but have found some with properties in decent shape and not worth replacing. I do understand the potential convenience I guess but as mentioned the overnight cleaners seem to work well. I also appreciate concerns about inappropriate or oversuse of caustic chemicals though.
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 03:19 PM
oven door seal replacement, self-cleaning function malfunction YerDugliness Appliances 10 02-28-2011 10:22 PM
Oven Install and Replacement- Dacor $400 CostcoMan Appliances 1 05-24-2010 07:02 AM
Gas oven problems gregsmy Appliances 1 12-03-2009 06:55 AM
Self cleaning oven Dee1 Appliances 6 08-03-2007 01:12 PM
