Cleaning Grease Off Of Kitchen Cabinets - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-10-2009, 11:37 PM   #1
Cleaning Grease off of kitchen cabinets
Can anyone offer me some advice on how to remove grease from wooden kitchen cabinets. It's in a home I bought as a foreclosure and it looks like the grease has been there for awhile. Are there any good deteregents that you have had success with?
brokenhammer is offline   Reply With Quote
Old 01-11-2009, 11:34 AM   #2
Rewards Points: 1,760
Is this prep for refinishing or are you trying to save the finish? Might try TSP (or substitute avail in big box stores) with one of those synthetic steel wool pads used for dishes (get no scratch version).
bob22 is offline   Reply With Quote
Old 01-11-2009, 11:46 AM   #3
Do these cabinets have a a stain finish, or paint finish. Are you prepared to refinish them after the cleaning? Usually the heaviest accumulation of grease is confined to cabinets about and around the stove. I've tried the degreasing type cleaners with varying degrees of success, but almost always unsatisfactory. I prefer to remove the doors with greatest amount of grease, and clean them in my driveway with mineral spirits and cotton rags. Wear chemical resistant gloves as well. Mineral spirits is a mild solvent and won't damage a varnished finish. If yours are painted, test the back side of a door first. Do not use gasoline! The cabinet facing and remaining cabinetry can be left in place, and cleaned with typical degreaser. Once again, do not use gasoline.
vf100 is offline   Reply With Quote
Old 01-11-2009, 06:44 PM   #4
There is no easy answer. Solvents that will remove grease easily could also damage the finish on the cabinets.
I've used Goo Gone along with a little elbow grease with pretty good success. You could also just try liquid dish soap, again with some elbow grease.
Whatever you use, try it out on the back side of the door first to make sure you aren't damaging the finish.
Jeeper1970 is offline   Reply With Quote
Old 01-12-2009, 06:13 AM   #5
Might look up some Murphy's oil type products for hardwood floors, etc
Chemist1961 is offline   Reply With Quote
Old 01-12-2009, 01:11 PM   #6
Rewards Points: 562
I had same problem.
somebody here sent me to Ace hardware and had me buy a degreaser in paint section.
It said to dilute in water. My grease was severe so I gave it to it full strength in a spray bottle. It took it off better than I ever thought it would,,but it also took off a few layers of paint,,,at least its 'clean' now to repaint,,,could NEVER paint over that grease ball of before.
With all the flippin shows they say to paint cabinets,,,I dont like painted cabinets BUT there comes a time when older cabinets do LOOK better painted than anything else,,unless you choose to reface them!! Only YOU can decide which you SHOULD do!! If painting over varnished surfaces,,get it ALL off first including finish. it is easier when you take them off and do it on a nice day in the driveway. number them somehow to make reinstalling MUCH less hassle
4just1don is offline   Reply With Quote
Old 01-12-2009, 04:42 PM   #7
bradnailer's Avatar
I'd try Murphy's Oil Soap.
bradnailer is offline   Reply With Quote
Old 01-24-2009, 09:41 AM   #8
Home Improvment Contactor
Murphy's is a good product. TSP another good 1. You could try Cabnet Majic. These 3 require lots of elbow grease and more than application. Acetone will get it but will hurt the finish. AKA fingernail polish remover without the additives. Evaporates quickly and is very flamible. So don't use the taoster, and shut off all piolits while useing it. It will also melt plastics so be careful. Natural stuff like vinegar and water, lemon juice or other citrus cleaners might work also.
Jack of most is offline   Reply With Quote
Old 01-25-2009, 12:06 PM   #9
Acetone is bad for brain cells so only use it outside, and wear chemical resistant gloves as it is absorbed through the skin and goes to the liver.
Timberwright is offline   Reply With Quote
Old 01-26-2009, 01:47 AM   #10
Rewards Points: 2,906
I do this all the time, and I find that Simple Green works well for cleaning the accumulated cooking grease off of kitchen cabinetry.
TSP will etch the gloss of any real varnish used on those cabinets.
I agree with the suggestion of using liquid dish washing detergent. What you're wanting to remove is nothing more than cooking oil that has condensed and accumulated on your cabinetry.
Mineral spirits will also remove that grease without harming the varnish or polyurethane on the cabinet doors.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 01-26-2009, 09:05 PM   #11
matermark's Avatar
Murphy's Oil Soap took 20+ years tobacco film off the interior doors with zero damage.
matermark is offline   Reply With Quote
Old 01-26-2009, 10:58 PM   #12
Greased Lightning. Cleaned 40 years of grease off of wood cabinets with it. I sprayed it on then scraped with a wide razor blade. I then sanded and refinished so I wasn't concerned with saving the original finish. Use gloves if you use it or it will harm your skin.
Simple Green works good as well but not as quickly as Greased Lightning.
KHouse75 is offline   Reply With Quote
Are kitchen cabinets standard sizes? Yeti Remodeling 8 01-30-2009 02:20 AM
diy built-in kitchen cabinets Jeremy Hillary Boob, PhD Carpentry 6 11-29-2008 11:46 PM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-20-2008 11:32 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 10:23 PM
