Cleaning Exterior Windows - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-31-2009, 07:50 AM   #1
Joel
Question
Can someone recommend a good apparatus for cleaning exterior (casement) windows? Thanks in advance
jweiner is offline   Reply With Quote
Old 05-31-2009, 08:06 AM   #2
Rewards Points: 5,336
If you can't clean both sides from the houses interior, you need a ladder.
They have these hose end sprayers for window cleaners, but I doubt it work's too well. The big boxes used to sell them.
Ron
Old 05-31-2009, 08:11 AM   #3
Joel
We live in a ranch and the highest windows are about 10- 15 feet from the ground. I was envisioning something to put on the end of an extension pole.
Old 05-31-2009, 08:45 AM   #4
the Musigician
DangerMouse's Avatar
buy one of the windshield cleaners from a gas station, mount it to a long pole.
DM
Old 05-31-2009, 09:00 AM   #5
Joel
but how do you recommend getting the windows wet?
Old 05-31-2009, 09:14 AM   #6
the Musigician
i guess you could throw a bucket of water at it or use a hose? or just use the scrubber/sponge on the flip side...
DM
Old 05-31-2009, 06:30 PM   #7
Rewards Points: 156
Some guy in my hometown made a window cleaning device that used a squeege (spell check on a long pole that I think might have been telescopic, and had a container like them old garden sprayers that you had to pump air in to pressurize. He had this hooked up so it ran a hose along the pole and would spray cleaning solution at the squeege and he would then clean the windows. Up and down Main street he would go and fast with that sucker. Otherwise you could try a RV cleaner, I had one that you could hook a hose up to and spray water through the bruch at the end, but it uses a brush , not a squeege.
creamaster is offline   Reply With Quote
Old 05-31-2009, 06:41 PM   #8
I thought you could clean a casement from inside the house?
The one that I did have has enough space on one end to wash the outside glass
Old 06-01-2009, 09:01 AM   #9
Rewards Points: 352
Dave,
Like the professionals you can buy a squeegee and a lambs wool scrubber that goes on an adjustable pole at a decent hardware store or were janitorial supplies are sold. Use the soap specifically intended for window cleaning, I am not sure why but it works better than other cleaners I have tried.
I tend to leave streaks with the squeegee so my little window cleaning trick is to use a drywall pole sander and a micro fiber cloth folded in half. Lightly spray the cloth with a 50% mixture of alcohol and water and polish away. If the windows are really bad I will wash them down outside with a bucket of soap and water using the lambs scrubber on a pole and rinse with the hose. When they dry I use the micro fiber cloth on the drywall pole sander, microfiber cloth and alcohol to polish them up. I also do this inside on two windows that are in dormers in our living room that are 16' off the floor.
Rege
RegeSullivan is offline   Reply With Quote
Old 06-01-2009, 09:48 AM   #10
the Musigician
here's what i did......
i didn't want to use a ladder either, so i made a tool for free from an old sponge mop handle retrofitted to a strip of jarrah with a windshield wiper blade (just the rubber part) PL'd to it. took all of a half hour to make and it works great with a sponge mop to wash and the wiper blade tool to dry. i keep an old towel handy to catch the dirt and drips from the tool and to wipe any off the window ledges. (white vinyl)
DM
Last edited by DangerMouse; 06-01-2009 at 09:55 AM. Reason: cause i'm an idiot.....
Old 06-03-2009, 10:59 PM   #11
I actually will need somthing as I installed 2 huge picture windows which are on the new 2nd floor. Most of the rest of my windows are all double hung TW. I have 2 awning windows - can be cleaned from inside. And I will have 4 small casement windows
Carpet cleaning - sump water n0c7 Flooring 17 08-29-2011 07:04 AM
Slate Tile Roof Cleaning Tampa Florida - Slate Roof Cleaning Using Lift. apple roof cleaning Roofing/Siding 1 12-31-2008 10:01 AM
Good equipment to use for carpet cleaning? Beth777 General DIY Discussions 5 08-29-2008 08:16 PM
sewer backup and stench jayhill Plumbing 12 08-13-2008 11:06 PM
