To Clean Or Replace The Tub Overflow Faceplate. - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-12-2013, 10:57 AM   #1
rkj
Rewards Points: 79
To clean or replace the tub overflow faceplate.
The one i have looks quite dirty:
http://i.imgur.com/gW3uz9Q.jpg
I don't know what it is, but its yellowish/brownish material on it. I tried kaboom, that didn't help not sure what else would work to clean it.
Should I just replace it? Is it difficult to do? I don't know if it requires a sealant/gasket in the back of the faceplate but if it does, then i want to avoid taking it out. I don't want to take it out, replace it, then find out water starts to go into its sides and behind the tub because i din't put in a sealant.
rkj is offline   Reply With Quote
Old 12-12-2013, 11:24 AM   #2
There no sealant required. As you mentioned, it's called an overflow..water is meant to go into it from a space at the bottom on the plate. When you remove the screws to take it off, you'll have to disconnect the rod from the drain assembly. It'll be pretty easy to see how it connects
Take the old one with you when you purchase a new one to replace. There's a variety of styles, and you of course you'll want to purchase one that'll hook up to your existing assembly.
RoyalAcresRod is offline   Reply With Quote
The Following User Says Thank You to RoyalAcresRod For This Useful Post:
rkj (12-12-2013)
Old 12-12-2013, 11:45 AM   #3
rkj
Rewards Points: 79
ok, thanks. I'll look around, maybe they have universal ones too.
Old 12-12-2013, 11:52 AM   #4
Rewards Points: 13,300
Very common item.
http://www.homedepot.com/p/Westbrass...-CP/202551041#
rkj (12-12-2013)
Old 12-12-2013, 12:52 PM   #5
rkj
Rewards Points: 79
thanks! What exactly is it that is on faceplate? Is it rust or calcium? They don't make anything at all that can clean it?
Old 12-12-2013, 01:35 PM   #6
Rewards Points: 2,072
I've had good luck with 'CLR' cleaning the bathroom.
Startingover is offline   Reply With Quote
Old 12-12-2013, 03:33 PM   #7
Sure looks like you could use a water softener.
Ever had the water tested?
Old 12-15-2013, 08:49 PM   #8
if your tap set is a moen brand you can take it to home depot and they will replace it free of charge, no questions asked
mapleleafsfan29 is offline   Reply With Quote
Old 12-16-2013, 02:54 PM   #9
rkj
Rewards Points: 79
thanks all, will look at something that will clean it first. CLR is just too toxic though.
Old 12-19-2013, 07:54 PM   #10
Rewards Points: 14
It's actually the chrome type finish that is failing. This is very typical from inexpensive plating and/or hard water. I just replaced ours last month. We live in So Cal and I think it's the hardest water in the U.S.
nvrfinished is offline   Reply With Quote
Proper Clean up after Toilet overflow leedee24 Plumbing 0 07-06-2011 02:24 PM
how to clean payne gas sensor? dapperdraker Appliances 3 06-26-2011 01:28 PM
Must I replace the coil when I replace the outside condenser unit? plichtenstein HVAC 5 08-24-2010 03:41 PM
Tub overflow drain? cbzdel Plumbing 1 05-11-2010 01:03 PM
replace galvanized pipe below kitchen sink? Jeremy Hillary Boob, PhD Plumbing 3 04-03-2009 09:39 AM
