-   -   To clean or replace the tub overflow faceplate. (http://www.diychatroom.com/f2/clean-replace-tub-overflow-faceplate-191911/)
rkj 12-12-2013 10:57 AM
The one i have looks quite dirty:
http://i.imgur.com/gW3uz9Q.jpg
I don't know what it is, but its yellowish/brownish material on it. I tried kaboom, that didn't help not sure what else would work to clean it.
Should I just replace it? Is it difficult to do? I don't know if it requires a sealant/gasket in the back of the faceplate but if it does, then i want to avoid taking it out. I don't want to take it out, replace it, then find out water starts to go into its sides and behind the tub because i din't put in a sealant.
RoyalAcresRod 12-12-2013 11:24 AM
There no sealant required. As you mentioned, it's called an overflow..water is meant to go into it from a space at the bottom on the plate. When you remove the screws to take it off, you'll have to disconnect the rod from the drain assembly. It'll be pretty easy to see how it connects
Take the old one with you when you purchase a new one to replace. There's a variety of styles, and you of course you'll want to purchase one that'll hook up to your existing assembly.
rkj 12-12-2013 11:45 AM
ok, thanks. I'll look around, maybe they have universal ones too.
joecaption 12-12-2013 11:52 AM
Very common item.
http://www.homedepot.com/p/Westbrass...-CP/202551041#
rkj 12-12-2013 12:52 PM
thanks! What exactly is it that is on faceplate? Is it rust or calcium? They don't make anything at all that can clean it?
Startingover 12-12-2013 01:35 PM
I've had good luck with 'CLR' cleaning the bathroom.
joecaption 12-12-2013 03:33 PM
Sure looks like you could use a water softener.
Ever had the water tested?
mapleleafsfan29 12-15-2013 08:49 PM
if your tap set is a moen brand you can take it to home depot and they will replace it free of charge, no questions asked
rkj 12-16-2013 02:54 PM
thanks all, will look at something that will clean it first. CLR is just too toxic though.
nvrfinished 12-19-2013 07:54 PM
It's actually the chrome type finish that is failing. This is very typical from inexpensive plating and/or hard water. I just replaced ours last month. We live in So Cal and I think it's the hardest water in the U.S.
