Chimney Has Simple Problem - Complicated Solution - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-17-2008, 05:53 PM   #1
Learning by Doing
Leah Frances's Avatar
Chimney has simple problem - complicated solution
My 1805 farmhouse has four chimneys. The eight fireplaces haven't been used in years, partially because of the 20 years of birds nests blocking up the flues. I would like to discourage the starlings and swallows from moving into the chimneys this spring. So I bought some 1/2 inch hardware cloth and rented a 40 foot extension ladder and had big plans for covering the otherwise uncapped chimneys today.
My only problem - the ladder wasn't tall enough. The roof is steeply pitched enough that I don't feel comfortable scrambling up it, and even if I did, I would still need a ladder to get to the tops of the chimneys.
How do pros do it? How am I going to get this done?
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-17-2008, 06:42 PM   #2
Rewards Points: 6,652
The pro's use a self-propelled Ariel Lift.
http://www.ur.com/index.php/equipmen...y=Aerial+Lifts
Oh, btw make sure that the wire you are using is Fire-Rated. Otherwise, contact a Chimney Sweep to take care of it. Plus side is, they can inspect the whole unit for you.
Old 03-17-2008, 06:43 PM   #3
Rewards Points: 5,336
I'm thinking you call a pro. The pitch isn't that steep. The 40' ladder gets him on the roof. You climb up above the chimney and insert the wire into the openings, reaching through the chimney to get them into the opposite sides if needed. Or wrap the cloth around the whole chimney and wire it together on the top side.
All the flues should be cleaned before you cover them
Ron
Old 03-17-2008, 10:44 PM   #4
Learning by Doing
my new neighbors have a line on a cheap chimney sweep. I think I might give them a call.
Old 03-18-2008, 08:12 AM   #5
Cheap is not always better. Shop around and find one that is reputable, not cheap.
Old 03-18-2008, 05:13 PM   #6
Learning by Doing
FYI - my husband wanted to buy me a 40 ft ladder. I insisted on renting first because I thought I would be afraid of going up it.
I wasn't (he was BTW).
However, a 40 ft aluminum extension ladder was too heavy for me (a woman who considers herself relatively strong). I returned it to the rental place by myself today.
It has been 0 days since our last workplace accident. Oh! my aching back.
Old 03-18-2008, 05:52 PM   #7
I blame ProWallGuy
Rewards Points: 150
You should have used the same line on him about the dueling garbage disposers.
Double A is offline   Reply With Quote
water leaking through brick chimney quigleybmd Concrete, Stone & Masonry 45 02-26-2013 05:26 PM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 12:23 PM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 04:12 PM
Simple problem that requires a complex solution. wfischer Electrical 18 01-07-2008 01:21 PM
