Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 10-26-2011, 02:06 PM   #1
Chimney Firebox Leak
My wife and I bought a 20 year old home last year and recently we had a chimney professional out to clean the chimney. While cleaning he indicated that a few things should be done and took some photos of the chimney to illustrate. The damper and grate was rusty so it seemed evident that rain had been getting in - some mortar in the firebox also needed repair due to water damage. In addition, he recommended a new crown (old was cracked) and flue liner. He also recommended a roofer redo the flashing and some overhanging limbs be removed.
We had all of this work done and then we had heavy rains for a few days. At that point I noticed that there was rain leaking into the firebox. It only appears to be leaking down the inside front and dripping onto floor of firebox.
I had the chimney guy come back out and put a new cap on and remove the old damper. I also asked him to look at the flashing that the roofer had done - he said it looked OK. It rained again and we still had the same problem.
So I had the roofer come back out to inspect his own work and also the work of the chimney guy to see if there was anything that looked like a problem. He indicated that everything looked fine.
It rained again last night and of course it is still leaking. So now the roofer and the chimney guy stand by their own work and claim that it is something that the other person did or did not do correctly. I don't want to pay a 3rd person to come out and look at it. I just want it fixed.
By process of elimination I would like to determine what the most likely cause of the problem is so that the correct person fixes it. How likely is bad flashing to cause a leak inside of the firebox? It seems more likely that it is a chimney issue.
This is really frustrating.
Victim is offline   Reply With Quote
Old 10-26-2011, 02:17 PM   #2
"Nail-Bender"
Post some pictures of the exterior of the chimney.
rossfingal
rossfingal is offline   Reply With Quote
Roof leak near chimney GlennAble Roofing/Siding 23 07-22-2011 07:52 PM
Persistent Leak - Chimney or Roof? CMoorhead Roofing/Siding 33 03-07-2011 09:46 AM
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 01:38 PM
Roof leak around my chimney - update GlennAble Roofing/Siding 3 11-05-2009 07:24 PM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 12:23 PM
