Chimney Damper Sealing - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-12-2010, 01:17 PM   #1
Chimney Damper sealing
I have a set of unvented gas logs in my fireplace. I know I am loosing a little heat past the closed damper.
I have looked for a thin insulation to lay in the opening and close the damper but I can't find any that is "fire-proof" enough to satisfy me.
Any suggestions?
Giles is offline   Reply With Quote
Old 02-12-2010, 04:04 PM   #2
Remodeling Contractor
Buy a chimney damper balloon. These are meant to perfectly seal the flue.
Chimney Confusion (Long) wehcyar Building & Construction 10 02-12-2017 06:16 AM
chimney leaking into attic kelley4180 Roofing/Siding 10 02-12-2010 09:55 AM
Chimney crown sealing hdhogger General DIY Discussions 1 12-10-2008 05:25 PM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 11:23 AM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 03:12 PM
