Chimeny Liner - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-15-2006, 02:36 PM   #1
Unhappy
Chimeny Liner
Chimney challenge in Northern Virginia!!
I recently hired a chimney sweep to sweep my home's chimneys prior to selling the house. The house was built in the mid 1960. The chimneys are used to vent gas fireplace logs. One has been used only once in 4 years, the other is used for about 30 hours each winter.
I have never had any problems with the chimneys.
The chimney sweep company now is trying to get me to spend $8900 to get the chimneys relined. The chimney sweeper put a remote video camera in the chimney and told me he could see problems with the terracota liner; when I viewed the video I could tell what we were looking at.
It feels like he is trying to scam me.
Anyone out there with a simliar experience.
tbuddy
Tbuddy is offline   Reply With Quote
Old 04-15-2006, 02:40 PM   #2
Is the reline a cement reline or a stainless steel liner?
A relative had a chimney relined and the price was around $650 for a stainless liner.
I would get a second opinion if you have concerns.
redline is offline   Reply With Quote
Old 04-15-2006, 10:14 PM   #3
Home Improvement Guy
ron schenker's Avatar
This was a wood burning fireplace converted to gas ,right?
ron schenker is offline   Reply With Quote
Old 04-21-2006, 06:38 PM   #4
Wood Burning to gas - yes - gas logs
I get the feeling that this damage to the mortar between terracota tiles in normal wear and I am getting taken to the cleaners. $8900 seems awful expensive. I had another inspection and a different company quoted about $6500. On the internet I get message that a few hundred dollars per chimney is more reasonable.....what is a home owner to do......Northern VA prices seem awful steep! And, I am not getting a good feeling that it is a REAL problem.
tbuddy
Old 04-21-2006, 06:44 PM   #5
Chimney Reline
I appreciate your response...I had another quote...about $6500. Not sure why it is so expensive. Northern VA price are high....but I still feel I am getting taken to the cleaners. Could the damage they show in the video be normal wear that is made to look like more of an issue with video. I have heard stories that chimney sweeps get a % of the sale if they can sell a reline.
tbuddy
Old 04-22-2006, 08:07 AM   #6
Did the estimates give you a break down of what the cost of materials and labor was going to be?
How tall is the chimney?
What is the diameter of the liner that they will be installing?
Old 04-22-2006, 12:37 PM   #7
Is the chimney on the exterior of the house?
If the chimney has three sides exposed the entire height of the exterior then the liner needs to have insulation (cost more) aka a double wall liner. If the chimney is located on the interior of the house and is only exposed at the roof then a double wall liner is not needed and is not as expensive.
Old 05-03-2006, 12:27 PM   #8
One thing for sure, if you're selling your house you'll never get that $8,900 cost back out of the sale, and I agree with the other posters that it's way to much money. Try to find a contractor that comes referred from a friend.
If it's a gas fireplace with an insert you may be able to put a metal flue up through it if code allows in your area. Either way, now that you know, you should disclose the uncertainty in a Seller's Disclosure when you sell.
SLCKev is offline   Reply With Quote
Liquid EPDM Rubber vs. EPDM 45-Mil Liner: Pros and Cons? WynsWrld98 Roofing/Siding 3 08-05-2007 12:44 PM
Chimney Liner vs New Furnace jeff_connors HVAC 4 01-11-2007 12:41 PM
Chimney Liner for Water Heater mruggeri001 HVAC 6 01-10-2007 06:08 AM
Advice Needed re: Chimney Liner for Oil Furnace Mike_R HVAC 3 11-27-2006 03:04 PM
Chimney Liner johnsonteam1058 Building & Construction 1 10-01-2005 10:39 PM
