Charged Plumming -- Dangerous? - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-06-2009, 04:08 PM   #16
Remodeling Contractor
Originally Posted by AllanJ View Post
As an amateur you can ground it yourself. Take a long length of wire (I suggest 16 gauge or thicker) and tie one end to the faucet assembly (the shower arm is better if you know a metal pipe connects the two). Run the cable through rooms and hallways and stairs (preferably stapled neatly along baseboards and up and around doorways) down to the basement and connect it to the ground bus bar in the breaker panel. Have the power off when you do this project.
Is this for real? Please specify the NEC reference for this method. And even your theory of how this makes sense.
Old 04-06-2009, 04:11 PM   #17
Seems as a Temp measure it would work
Not sure how good it would look
But better then being shocked in the shower
Old 04-06-2009, 04:18 PM   #18
All the plumbing pipes are connected. (unless the basement is flooded). So connecting a #6 which is code minimum to the nearest copper pipe is a much easier and safer and correct fix. Also in same department you will find a clamp for the pipe and wire since this is done at every house in the world unless all the plumbing is plastic.
Old 04-06-2009, 04:19 PM   #19
I wasn't aware you went & inspected the property
Unless of course PVC was inserted somewhere
Old 04-06-2009, 04:48 PM   #20
electrician
No AllenJ, as an amateur you shouldn't be touching any electrical in a rental!
Silk is offline   Reply With Quote
Old 04-06-2009, 05:10 PM   #21
If I was in a rental & I was getting shocked in the shower you bet yer arse I'd touch the electric by running a ground
Old 04-08-2009, 09:12 AM   #22
Bill Kearney
Rewards Points: 1,174
A quick way to find the source of the problem would be to turn off the breakers. Start with them ALL off. If you want to be safe then use a voltmeter to check it instead of just your bare hands. If the voltage disappears when all the breakers are off then start turning them back on, one-by-one until it returns. Make note of which one triggered the return of voltage and turn it back off (and leave it off until it's fixed). If the breaker is controlling something like a dishwasher, refrigerator or other appliance, try unplugging that appliance (if it has a plug). It may be a defect within that appliance that's causing the problem. Or it may be a defect in how the outlet for that appliance is wired.
When I was a kid we had a fridge that wasn't grounded properly. We never noticed the problem until I was tall enough to reach both the kitchen sink spigot and the handle of the fridge at the same time. Zap! Unplugging the fridge eliminated the problem. Running the fridge from another outlet (with a heavy duty extension cord) likewise eliminated the problem. Turned out to be an improperly wired outlet.
If you turn off all the breakers and the voltage is still there then try shutting off the main breaker. If turning off all the breakers doesn't eliminate the voltage then there's a much bigger problem.
It's a rental, so you're stuck on just what you can do to fix it but you should NOT be playing games with your safety. Live voltage on water pipes is a serious risk. Do not half-ass it here by rigging up something on your own.
wkearney99 is offline   Reply With Quote
Hot light switch - how dangerous, and what to do? maximizer Electrical 12 12-29-2011 10:19 PM
Elecrtical Panel Dangerous??? Trouble-T Electrical 7 09-24-2008 06:44 AM
Solar Charged Brushless Lawn Mower Educator Electrical 2 04-20-2008 12:43 PM
