Changing Reverse Osmosis Water Filters - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-04-2008, 06:55 PM   #1
Unhappy
Changing reverse osmosis water filters
Recently bought house with reverse osmosis water filter unit under kitchen sink. No instruction manual. Have a large plastic "key" apparently intended to remove the bottom of filter "cans" (3), but am unable to loosen them. Are they possibly reverse threaded?
awayeli is offline   Reply With Quote
Old 07-05-2008, 09:17 AM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,360
They're not reverse threaded.You have to put some muscle behind it to get them to turn.
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
Old 07-05-2008, 02:20 PM   #3
showerob
Perhaps you need to move the key up so it fits tight before you turn it. I had a similar problem before and like the previous message, turn it hard but carefully. Hopefully it's not because the previous owner of the house did not change the filter for a long time and there is now excessive dirt along the fittings.
showerob is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 10:29 PM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 09:03 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
