Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 07-26-2009, 08:43 PM   #1
Changing existing brick mortar color
Here is a odd question.
We currently have a brick fireplace that has BLACK mortar between the brick. As we are remodeling and want to keep the brick, I would like to change the mortar back to natural gray. Any suggestions of how to accomplish this. Has anyone done this before, or anything simular to it?
Thanks for any insightful responses.
bladesj is offline   Reply With Quote
Old 07-27-2009, 06:59 AM   #2
It could probably be painted, but the only way to permanently change it is to grind it out and repoint with the color you want.
Old 07-29-2009, 04:35 PM   #3
Dye for tile grout would most likely work. Try it in a unnoticeable spot.
NJ Brickie is offline   Reply With Quote
Old 07-23-2010, 11:27 AM   #4
I am facing the same problem....how did yours turn out and what did you do? Are you happy with the results?
gbell is offline   Reply With Quote
Old 07-23-2010, 12:55 PM   #5
Sorry, I have decided to leave it alone and have not made any changes.
Old 07-23-2010, 02:41 PM   #6
A "Handy Husband"
rjniles's Avatar
A dye would work if going from a light color to a dark color (but the color might not be exactly as you expected), but not from black to a light color. I definitely would not paint it unless you are painting the brick. Chipping or grinding out and re-pointing is the only real option.
Coastal South Carolina
rjniles is offline   Reply With Quote
Changing mortar color? kcrossley2 Concrete, Stone & Masonry 20 03-17-2012 09:01 PM
Bad Brick Mortar ??? kourso Building & Construction 21 11-08-2010 01:11 AM
how to make white mortar for brick wall nhertel Building & Construction 2 05-26-2009 09:22 AM
Can I dye existing brick mortar? Foo by Tore General Discussion 2 10-30-2008 08:03 PM
Mortar removal from salvaged brick. Rem8 Building & Construction 8 07-20-2008 08:05 AM
