Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-14-2007, 11:35 PM   #1
Question
changing drop ceiling to normal ceiling
can anyone give me advice on changing out a drop ceiling to a normal ceiling. i recently bought a house that has an entire floor of drop ceiling tiles and i want to change it. i have about a 10" space b/w the upper floor joists and the tiles. Please help. I have no real idea of how to do it.
acoustic_bum is offline   Reply With Quote
Old 01-15-2007, 12:04 AM   #2
Darylh's Avatar
One of the reasons they put drop ceilings in is because of electrical, plumbing, hvac ot other obsticles hanging below the floor joists so you will have to see whats up there to see if its vesible or not.
Darylh is offline   Reply With Quote
Old 01-15-2007, 12:09 AM   #3
i know there is a couple plumbing pipes running across but they are small and attatched to the bottom of the joists of the upper floor. But there is still plenty of room below it. The only thing is about how to support the ceiling. obviously i can't just nail it up to the joists. so i guess i'm going to have to create a subfloor. any thoughts?
Old 01-15-2007, 12:32 AM   #4
Darylh's Avatar
Strap it with 1x4 (if thats enough to clear your water pipes) 16" o/c in oppisite direction of your joists.and screw them in.You may have to go with 2x4 but either way just strapping should do the trick.
Old 01-15-2007, 12:43 AM   #5
do i need to get it inspected?
Old 01-15-2007, 01:32 AM   #6
Oldguy
Rehabber's Avatar
Only if you enjoy dealing with inspectors
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 01-15-2007, 08:24 AM   #7
Probably.Call the jurisdiction that you're in and ask them what they need.
tkle is offline   Reply With Quote
Old 01-16-2007, 08:52 AM   #8
Darylh's Avatar
You may not need a permit but they will probably tell you you will need a electrical permit for moving any boxes and wiring so give them a call.
Drop ceiling in basement bathroom handyflyer Remodeling 23 05-26-2009 10:12 PM
Recessed lighting in drop ceiling DIY4EVER Electrical 9 06-04-2007 05:46 AM
Pool Table Light in Drop Ceiling JJdeadhead Electrical 5 04-18-2007 09:01 AM
How do you convert a drop ceiling to a normal ceiling??? acoustic_bum Remodeling 8 01-16-2007 11:55 PM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 09:27 AM
