Chain Link Gate Accross Driveway - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-30-2013, 06:20 PM   #1
Lord of Slums
Rewards Points: 1,974
Chain link gate accross driveway
I need to set two 5 foot chain link gates across a driveway. I want to set metal posts in concrete. Total span will be ten feet, joined in the middle with some sort of latch. What size metal post should I use on the ends to support the wait of the gate, how big of hole should I drill into concrete? Should I rent some sort of hammer drill and bit for 70 bucks, or should I buy a Bosch hammer drill and make a bunch of small holes and punch out the hole that way? Any tips? Never done this before.
mj12 is offline   Reply With Quote
Old 04-30-2013, 06:46 PM   #2
Rewards Points: 6,652
Usually you have one gate, with a steel 1/2" rod bent as a L, so that you can lift it up to move that one gate. This way the rod will hold the two sections in place, without them moving around. If you place a post in the middle, then you have to pull it out, after lifting the gate latches, to open.
Old 04-30-2013, 06:55 PM   #3
A 5' gate is not heavy unless fabricated by a Pro with Sch 40 pipe. A 2 1/2" x 7' gate post with cap will do. If you are of the mind set "Bigger is Better", use a schedule 40 gate post. Drilled hole should be twice the diameter of the post and beveled larger toward the bottom of the hole. Set the bottom of the post in the soil, about 2" in to allow for drainage of moisture. Set the post to allow desired ground clearance plus a little reveal above the gate. I don't know what hardware you are using to hang and couple the gates. Lay them out on the ground as if closed and measure distance to inside edge of gate post hinge. Add 2 1/2" to this and this should be your center distance for the holes. Closer is forgiving, wider is not. Pay close attention to level when pouring concrete. Don't be in a hurry. Let the concrete set over night. Quick setting concrete is available if need be.
If you have future use for a hammer drill, by all means by one. It is nice to have when drilling concrete for other projects.
Johnmcm1 is offline   Reply With Quote
Driveway gate control board lightening issues walt1122 Electrical 6 11-05-2012 11:51 AM
Installing vinyl fenching over chain link? rbove8 General DIY Discussions 3 05-02-2011 10:54 PM
Posts in a chain link fence.....cemented down yummy mummy Landscaping & Lawn Care 0 07-14-2008 10:54 AM
Chain Link Fence Privacy? the question General DIY Discussions 2 06-15-2008 11:08 AM
Chain link problem? jeremylindquist Landscaping & Lawn Care 1 06-24-2007 07:34 PM
