Ceramic Tile Transition To Laminate - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-01-2010, 09:28 PM   #1
ceramic tile transition to laminate
Help! I have laminate floor and already installed transition strip to carpet. Removed carpet to install tile. Laminate transition piece and tile are flush...my question is, do i space the tile off the strip and grout as I would the entire project, or do I butt the tile against the strip (which is straight and square) with no grout? If I do space it and grout, should I install a metal edge between strip and grout with the metal edge butted up to the laminate transition strip?
Kman92592 is offline   Reply With Quote
Old 07-01-2010, 10:55 PM   #2
Rewards Points: 5,326
You need to leave an expansion gap around the perimeter of any laminate floor. The flooring you're using has a "T" molding that will go between the laminate and the tile and cover the intersection and the gap.
Ron
Hardwood transition to ceramic tile willyberger Flooring 5 08-09-2009 12:38 PM
Transition laminate to higher fireplace tile Slippin Flooring 1 03-17-2009 09:22 PM
Transition from hardwood to ceramic tile. tmbrink Flooring 1 03-09-2009 01:04 AM
Marble to Ceramic tile transition stormsurfin Flooring 3 06-18-2008 11:46 PM
tile to laminate transition SML93 Flooring 5 03-22-2008 06:11 PM
