Ceramic Tile Installation Cost - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-17-2009, 12:23 PM   #1
Ceramic tile installation cost
How do you know if you are being quoted a fair and reasonable cost for tile installation. Is there a general formula? I roughly have a 500 sq. foot area that needs to be tiled in a remodel. The space is clear and open, on concrete, so I don't think there will be a lot of strange or unusual cuts. I live in N.M. also
tjhiller is offline   Reply With Quote
Old 07-17-2009, 12:36 PM   #2
RippySkippy's Avatar
If you feel the price is fair...then it is. The only equation is between you and the contractor for said job...either you agree (accept the quote) or disagree (reject the quote).
The best way to help you sort that out; since this site is not a place that commonly prices goods/services due to regional/job differences, is to get comparable quotes from multiple contractors...just make sure the scope of the project is comparable . If you don't like the first 2 or 3 quotes, find a couple more. You will soon discover similarities and identify differences which will help you with the decision making process. BTW -- request references from all contractors submitting a bid, and follow-up with them before signing any contractual agreement.
Good luck...
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 07-17-2009, 06:55 PM   #3
Rewards Points: 5,336
If you call 3 -4 contractors and get estimates, you will get a good idea as to price. Usually larger companies will be higher in price then smaller companies.
Ron
Old 07-18-2009, 09:49 PM   #4
Hey there TJ. Unless you do get other quotes. There is no way knowing that you have been given a fair price. The best thing to do is get 3 quotes and compare. Also ask them if they charge by the hour and how long it will take to do the job. Some charge by the area (size) they are working with.
Not sure if you can do this were you live. But where I am. I can usually make a phone call and get estimates of rate. Have your room size ready measured up because they will want that info.
Then with the quote have now. Do some maths. If quoted by area (quote divided by area.) this will give you a price per m2. If quoted by hourly rate(quote divided by total time) this will give you an hourly rate. Do this with all quotes and you will get the best price.
Tip: You should always try and take a look at their previous work or credentials. Cos, you have pros and so called pros. The cheapest could also turn out be the worst job.
Also you say you have a concrete floor that's square. You are correct. There will be no unusual cuts. Depending on the size of your room as opposed to the size of tiles you have chosen, there will be cuts along the egdes, near the walls and cuts near your doors. A good tiler should take the time to cut these tiles to fit nicely around your door jambs.
Any hope this helped.
Cheers Marianne
PS. You could always try to DIY!!!
diy-er is offline   Reply With Quote
Ceramic Tile on Concrete Slab fight3club Flooring 2 04-06-2009 07:32 AM
ceramic tile to wood floor threshold bjs Flooring 23 11-28-2008 09:35 PM
a couple of ceramic tile install Q's DanBress Flooring 5 06-22-2008 11:01 PM
Removing Ceramic Tile csnolan General DIY Discussions 1 10-26-2007 11:37 PM
Ceramic tile on a little step... kbens74 Flooring 8 01-04-2007 11:45 AM
