Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 10-20-2008, 02:14 PM   #1
ceramic to ceramic transitioin
how to you transition between two ceramic tiles? one is laid on diagonal and new to be in straight pattern.
julied is offline   Reply With Quote
Old 10-20-2008, 08:26 PM   #2
One way would be to use ornamental strip tiles. A vertical line would be cut in the diagonal tiles. Then the ornamental tiles placed to this line. Then the straight tiles would be placed, abutting the ornamentals.
If you could post a photo, it may foster other ideas.
Old 10-22-2008, 05:00 PM   #3
You could use a stone saddle to abutt both tile directions.
Ron
Old 10-22-2008, 11:32 PM   #4
what is stone saddle?
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 07:12 PM
porcelain versus ceramic tile pandora Flooring 55 11-24-2008 10:01 AM
How do I remove this ceramic tile? tripower Flooring 5 07-23-2007 10:45 PM
is this subfloor strong enough for ceramic tile ? mf915 Flooring 2 07-01-2006 08:02 AM
ceramic pipes am_miller Plumbing 1 01-12-2006 10:30 PM
