Central Vacuum Outlet Wiring Problem - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-24-2011, 07:11 PM   #1
Central vacuum outlet wiring problem
Hopefully this is the correct forum....I had to replace an outlet for my central vacuum system, but when I hooked up the wires the way they came off the old outlet, the vacuum turns on. There are two wires for each screw and I was careful to keep them in the correct order. Do I have an incorrect outlet for the system and if so, can I change the wiring to make this work? Thanks for any help.
Tinker44 is offline   Reply With Quote
Old 10-24-2011, 07:46 PM   #2
Problem solved!
No replies needed, thanks. After reading a few posts on this subject, I realized that I HADN'T been so careful with keeping the wires in the correct position. Once I put white with white and black with black, it all works fine.
Old 10-25-2011, 08:37 AM   #3
Rewards Points: 5,336
Now that's DIY!
Ron
B. Franklin 1759
Problem Wiring A Porch Light AuD14 Electrical 5 10-31-2010 10:09 PM
Central Vac problem strongbow Electrical 4 10-23-2010 08:49 PM
outlet problem hokie_engineer Electrical 13 03-18-2010 03:55 PM
Problem with wiring (really long post sorry) okacookie Electrical 10 04-21-2009 08:54 AM
Wiring a new outlet advice kennykenny Electrical 19 08-29-2008 10:54 AM
