Central Vaccum Problems - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-20-2007, 11:37 PM   #1
Rewards Points: 123
Anyone know knowledgeable about central vacs? My wife was using ours the other day and it made a noise, not good sounding and smoke came from the motor area. Now it doesn't sound right at all when turned on. Is the motor shot?
jerome8283 is offline   Reply With Quote
Old 06-21-2007, 09:31 PM   #2
Eibwen
Could be a burnt motor winding or bearings... I would check the filter, then the motor.. Might be something wrapped around the motor thats seizing it up.
Most arent too bad to replace.
Sammy is offline   Reply With Quote
Old 06-23-2007, 07:56 PM   #3
Rewards Points: 123
ok here's a better description of the problem and current status..
When I turn the unit on it sounds like a blender, as if something is caught up in the motor. I get no suction at all. Today I opened the unit up to inspect it. The main filter was very dirty and the small filter just before the motor was clogged. I cleaned everything up and blew a little dust out of the motor. This didn't make a difference. The motor sounded the same.
At this point I was convinced the motor was shot so I took it to my local Aerus Electrolux store. The Service Manager told me the motor was shot. His cost to replace the motor was $250(motor) + $50(labor). He tried to sell me a new vacuum for $699.99. His reasoning was the replacement motor would only have a 1yr warranty and the new vacuum would have a 5yr warranty. But my reasoning said, $300 is too much for the motor and I don't need a new $700 vacuum. I've seen the motors online from $150 - $250. Although I've seen the motors online I'm not sure which sites are reputable? Can someone recommend some?
Old 06-23-2007, 08:15 PM   #4
Eibwen
Is the unit made by Electrolux?
If not, may be able to find a motor elsewhere but I'm not sure on any web sites.
I have a 30 year old Electrolux canister and they are known for thier quality, but pricey.
Old 06-23-2007, 08:21 PM   #5
Rewards Points: 123
It's an Electrolux 1590, central vac
Old 06-23-2007, 08:33 PM   #6
Eibwen
Hmmm..
The only other thing I could suggest is check and see if there is an ADI alarm distributor in your area. They may have a sub for the motor. Or maybe check the motor for a nameplate.. Maybe somebody else made it for Electrolux.
Old 06-23-2007, 08:55 PM   #7
747
registered
747's Avatar
Rewards Points: 534
I personally think that 300 isn't bad. About a year ago i brought my upright electrolux vac into them they charged me like 90.00 to get it running again something about the cord. I would pay the 300 but definately wouldn't let him shake me down for a new unit. What probably happened was this. You weren't taking care of that thing the way you were suppose to. You should have made a point every couple of weeks to clean the filters. They got so clogged that the motor had to work harder then usual thereby burning the motor up. My upright i like because it has the drop in bag i don't care for those new uprights which have the filter and the canister you empty. Pay the 300 and be done with it. Unless you could find a motor online somewhere cheap and then pay a electrician 50 to install.
747 is offline   Reply With Quote
Old 06-23-2007, 09:10 PM   #8
Rewards Points: 123
Your right about me not cleaning the filter but, I'm not sure I want to pay $300 when I see the motor online for half that. I can install the motor myself.
Old 06-24-2007, 07:05 AM   #9
747
registered
747's Avatar
Rewards Points: 534
By all means by that motor online and install it yourself if you can save money
Old 06-29-2007, 11:30 PM   #10
Rewards Points: 123
I took delivery on my Lamb Central Vacuum Motor today. The install took me 16mins. Works like a charm!
I only paid $144 bucks for the motor!
Here's the site: http://builtinvacuum.com/products_home.html
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 02:51 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 04:51 PM
Problems with Central Air Cooling System golfgod04 HVAC 4 05-27-2007 09:51 PM
Installing Central Air using existing heat ducts lvlacic HVAC 2 06-25-2005 01:47 AM
